Old 11-29-2009, 08:13 PM   #1
jmedero
jmedero's Avatar
my 66 started throwing up today!! help
well I have started to work on the engine in my 66. Its a sbc 350 that has not been started in like 6mths. Well I put on a new carb Edelbrock endurashine 650 4brl and a new battery. Well tried to turn it over and nothing, just tried to turn over. Well I killed the battery, charged it over night and started again today. I pulled out plugs to put wd40 in and turn it over without the plugs in to lube up the cylinders, here were it got scary for me. When I turn it over without the plugs cylinder 6 and 8 are spewing out gas! I mean alot of gas! Whats the deal? Why is it doing this? Any help would be greatly appreciated.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 11-29-2009, 08:22 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: my 66 started throwing up today!! help
You have a float stuck (down) with the needle/seat open in the carb.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-29-2009, 08:32 PM   #3
jmedero
jmedero's Avatar
Ok I have never gone inside a carb. What am I looking for?
Old 11-29-2009, 08:48 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Take the carb off and shake it vigorously. That will likely dislodge the float. When you turn the carb slowly upside down then right side up you should hear the float clank around inside the carb if you listen close.
Old 11-29-2009, 08:50 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Page 14 of the attached link explains how to adjust the floats. I picked the 1400/1403 series, not sure exactly which one you have. If it's the wrong version just go back to the home page and click on the Tech Support link.
http://www.edelbrock.com/automotive_...403_manual.pdf
