Old 11-29-2009, 10:00 PM   #1
hillbillyrider
4x4 trans what years will work
i have a 77 model chevy 4x4. it has the bulldog 4 speed in it. the transmission busted the other day. i was wondering what years will interchange on the trans. i want a direct bolt in. thanks in advance
hillbillyrider is offline   Reply With Quote
Old 11-30-2009, 09:45 PM   #2
BIG V
Re: 4x4 trans what years will work
the Bulldog as you call it is the sm465 it will work with 4wd models only from 1972-80 the earlier ones didnt have syncros the later modelones has syncros on the 1st gear
BIG V is offline   Reply With Quote
Old 11-30-2009, 10:02 PM   #3
hillbillyrider
thanks, thats what i needed to know
Old 12-01-2009, 02:26 AM   #4
sailed2japan
Jonny
sailed2japan's Avatar
Will earlier/later models not bolt up?
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 12-01-2009, 05:02 AM   #5
2tons of fun
wtf?
they will bolt up to ANY sbc/bbc.
will work with ANY tcase from the t221 to the np 203 205 208 231 241, with the proper STOCK adapters.
intsalled from 69-91.
mech clutchs till 85, hydro after, doesnt affect the tranny at all, is only the bell housing.
the only 2 real changers are in the LATE 80's when the changed from a short 10spline to a long 32spl out put for the aluminum tcases and the round pattern 205's. and they changed the top to aluminum in 88ish.
granny gear was never syncro'd afiak.
gm used the 465/205 all the way up to 91.
2tons of fun is offline   Reply With Quote
Old 12-01-2009, 05:05 AM   #6
2tons of fun
depends on what you want to do or swap to.
you can swap an entire setup if you want, or swap a rear output if you feel like getting dirty or have a particular case you want to use.
far and a way the most versitile trans gm ever used. can be found on 2wd half tons, dump trucks, crew cabs, dually's and 4x4, hell the only thing they didnt come in was cars.
Old 12-03-2009, 02:39 AM   #7
hillbillyrider
heard dat. thanks for the replies. picked up a trans and t-case yesterday for $400. and it came out of a 77. imagine that, could hardly find one and when i did, its the same year as mine.
Old 12-03-2009, 03:05 AM   #8
BIG V
Originally Posted by 2tons of fun View Post
wtf?
for his 1977 only 1972-1980 will work thats wtf 81 went to 35 spline and a different adapter 1971 you have to change the output shaft nuts to fit in to his adapter. so like i originally stated 1972-80 will work. thanks for all the useless information about all that won't work with his 1977 t-case.
Old 12-03-2009, 12:18 PM   #9
charlie diaz
charlie diaz's Avatar
also, the 205 was replaced by the np208 in 1985
charlie diaz is offline   Reply With Quote
Old 12-04-2009, 05:01 AM   #10
2tons of fun
uh, 35 spl is 2wd ONLY!!
there are no OUT PUT SHAFT NUTS on a 4x4, again 2wd ONLY
i have pulled many 10spl 465s out of newer than 82
Old 12-05-2009, 02:33 AM   #11
mickman77
mickman77's Avatar
Sorrry 2tons, I've gotta agree with bigv. The 205 I bought last weekend came out of an 87 K3500 (took it out myself). It had the SM465 true enough BUT, the transfer had a 32 spline female input...SOOO, the 465 musta had a 32 male output. Not 10.
'77 K20 LWB 454, NV4500, NP205, 4.10's rollin on 33's passin everything but a gas station.
mickman77 is offline   Reply With Quote
Old 12-05-2009, 02:38 AM   #12
BIG V
sorry my mistake 32 spline not 35 but i was close
Old 12-05-2009, 02:58 AM   #13
2tons of fun
didnt say they didnt exsits, i said that the 10spline ran longer than 80-82, which you just confirmed.
Old 12-05-2009, 09:47 AM   #14
68 TT
Still plays with trucks
68 TT's Avatar
Any idea what year the change to 32-spline occurred?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
