Old 11-29-2009, 10:01 PM   #1
ksbeatty
ksbeatty's Avatar
69 GMC Front Lenses
I am little confused. As normal. I am looking for the assemblies for the grill on this 69 GMC. I am assuming they are called turn signal lenses and the side markers are called such or parking lamps.
1969 GMC 3/4 Ton 4x4
2" Lift, A/C, PS, PB
383 Stroker, 700R4, 205, 4.10 GM
Medium Bronze (Copper Poly)
no new nick name yet. She is to pretty to be the Beater.
http://67-72chevytrucks.com/vboard/s...d.php?t=241855
ksbeatty is offline   Reply With Quote
Old 11-29-2009, 10:09 PM   #2
Jurassic-1
Jurassic-1's Avatar
Smile Re: 69 GMC Front Lenses
The front lenses in the grille are turn signal lenses and or park lamp lenses the side are marker lamps
Jurassic-1 is offline   Reply With Quote
Old 11-29-2009, 10:29 PM   #3
Mowdigger
Mowdigger's Avatar
Check out GMC Pauls or LMC truck parts. They should have them.
Mowdigger is offline   Reply With Quote
Old 11-29-2009, 11:10 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Any of the vendors here should be able to help you out..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-30-2009, 07:13 PM   #5
mikemileski
All you can buy for GMCs is the lenses themselves. The aftermarket makes complete turn signal assemblies for Chevys, but not for the GMCs (at least, none that I'm aware of).
Mike Mileski
Tucson, AZ
mikemileski is offline   Reply With Quote
Old 11-30-2009, 08:12 PM   #6
Mowdigger
Mowdigger's Avatar
Put a piture of the part you are wanting on this thread. If a 70 is the same, I know where a parts truck is at, and I'll see if the parts are still there.
Mowdigger
