Old 11-29-2009, 10:05 PM   #1
lclippard
lclippard's Avatar
air conditioning
does anyone know if the ac unit from a 73-87 chevy truck will(can be modded) to fit our trucks? found a 87 cab online that has a/c and it looks alot like the factory setup on our trucks. just curious, cuz im not a fan of the aftermarket add-on setups.
69 burb/01 yukon chassis
65 Comet Caliente 289 4 Door Sedan
99 Millenia S (supercharged) 4 Door Sedan
02 Yamaha R6
69 swb c10 http://67-72chevytrucks.com/vboard/s...36#post3799136
building with a buddy:
85 C10 http://67-72chevytrucks.com/vboard/s...94#post3708194
lclippard is offline   Reply With Quote
Old 11-29-2009, 11:05 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: air conditioning
Anything is possible but im betting that would be a great amount of work?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-29-2009, 11:11 PM   #3
westofb
I really hate wet sanding!
westofb's Avatar
I pondered this myself seeing that I have a junk 85 a/c cab sitting around. I will not say that it can not be done, but looks to be next to impossible. The housings are nothing alike, the area behind the dash on the newer trucks is larger than the older ones so I doubt you could physically squeaze the heater/ air box behind the dash of these trucks. I never put a tape to anything, but just looking things over I decided even against removing the pieces from the 85 and attempting such a feat.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 11-29-2009, 11:15 PM   #4
lclippard
lclippard's Avatar
i see. well like i said i just saw a pic of a cab, and it looked similar, but i havent gotten any where close to that body truck in forever. wasnt sure how different it was. thanks for the replies.
02 Yamaha R6
