9 inch swap
How hard would it be to swap in a 9in rearend for my 75 half 2 wheel drive? I would like to be able to swap gears fairly easy. thanks.
Re: 9 inch swap
Pretty easy if you get the right rear axle . Search the internet and you will find that some Ford big cars came with a 5 on 5 inch bolt pattern and are almost the exact same width as our trucks . They can even be had with factory rear disc brakes and the 5 on 5 bolt pattern .You would only need to trim the existing mounts and weld on a pair of universal mounts that can be bought at retailers like Summit . I see them on the internet at times and the rears that will work in our trucks are not that expensive . Most have serious highway gear since they were used in the big luxury cars but that is easily cured .
Frank
Born and proudly residing in a Red State ! |
Re: 9 inch swap
I know the ford 9in is common unlike some of the 12 bolts. I like the idea of being able to swap the pumpkin so easy. I just had my 12 bolt posi rebuilt and set up for my chevelle and now im stuck with the gear i chose. With the truck i want the option to tow or cruise. Probably use bags all around and i have a 454 to swap in place of the 350. Also ford has a wide selection of gears for the 9in.
Re: 9 inch swap
so, it will still take you 2+hrs to swap, and 3-4qrt of oil, because who is cheap/dumb enough to reuse oil.
you will be ahead if you just bought an entire second axle and setup matching disc brakes. just take the calipers off, then dshaft, shocks, ubolts. clean and no waste. no need to bleed the brakes, reseal or refill. |
Re: 9 inch swap
i had a ford 9 inch an broke both axles in it pulling of from stop lights . an no i was not spinning or anything just eased out on the clutch an bam .they kept snapping at the wheel bearing where it bolts to the axle tubes . by the way all the truck had in it for motor was a 300 6. so be carefull what axles you get the more splines thhe better
At the body shop.
Re: 9 inch swap
79 f-150 housings are about a inch wider. Come with big 3 1/4 axle tube and the heavy duty center sections. And the drive shaft needs to be a bit longer also. And you to fab the brake lines fords brake lines come down the left side of the frame.
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 12-05-2009 at 03:16 PM. |
Re: 9 inch swap
are these 5 on 5 though???
![]() Join Date: Jul 2009
Re: 9 inch swap
No, the bolt pattern is wrong, but all you would have to do to remedy this is to pull the axles (which you would have to do anyway to install the gear choice that you want) and have them and the drums drilled to the appropriate 5x5 bolt pattern. They would just drill the appropriate pattern between the existing pattern. And yes, this would be plenty strong...and I have never heard of a 300 straight six breaking a 9" axle...EVER.
At the body shop.
Re: 9 inch swap
I bought moser axles. Ordered them 5x5 and took a die grinder to the drum's, they register on the axle flange...
" That didnt make it any newer " " Dont antique the equipment " |
#10 | |
Still plays with trucks
Re: 9 inch swap
I even had storage boxes that fit in a cabinet on the trailer that held the spare pumpkins and kept them clean & undamaged.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#11 | |
Re: 9 inch swap
The easy way to tell is the 28-spline rear ends have smaller bolts holding the axle retainer plates in place. If it has 9/16" heads on the retainer plate bolts it is a 28-spline rear. You probably had the 28-spline 9" with a 6-cyl.
#12 | |
Re: 9 inch swap
