11-30-2009, 08:26 PM | #1 |
Turn Signal Help
So I want to customize my factory steering wheel, it is totally trashed. The plastic covering the wheel is completely cracked and falling apart. I mean 1/2 inch cracks even on the center. So until it's done I'm using a wheel from a 1988 2500, that's where my problem starts. The conversion went well but now the turn signals don't work properly. The right doesn't work at all, the left works half speed. I also took out my instrument cluster to replace blown bulbs. Yes I checked all bulbs and they are good now.
12-02-2009, 12:10 AM | #2 |
70 Chevrolet=Obsession
Re: Turn Signal Help
Did you check the bulbs for the front and rear turn signals themselves? I would make sure everything lights up on the outside before you go any further. Are you still using the stock turn signal assembly? If you changed it, it may be a wiring issue.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
