Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-30-2009, 09:26 PM   #1
ripdog28
ripdog28's Avatar
What helps RPM's?
I am looking at changing my valve springs,cam in hopes of getting a 7-7500 rpm reliable engine. Do i need a lighter Crank,rods,piston or is it mainly the cam and springs. I do know all help but can you pick up more RPM's from cam and springs or by the balancing?
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 11-30-2009, 10:18 PM   #2
DieselEater
DieselEater's Avatar
Re: What helps RPM's?
Bottom end in your sig should be fine upwards of 8K RPM. I would recommend Isky red zones with a solid roller cam, and aluminum roller rockers. Of course you need high flowing heads to hit 8K.
Gearing will get you there also, but may slow you down at the same time...LOL
Check out this site for BBC advice!
http://www.chevelles.com/forums/forumdisplay.php?f=13
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 12-01-2009, 08:57 PM   #3
Marv D
Registered Truck Offender
Marv D's Avatar
462" takes a lot of piston swinging around, and a lot of stroke. It's the crank forcing all that heavy weight to change directions that typically rips a rod cap off or piston pins out of a piston. I'd be cautious on the top end when you snap the throttle closed.
Myself I'm not a fan of the KB piston line. Do you know what they weigh? As a comparison a typical JE BBC 460 flat top is in the 550 - 590gram range. Whatever you do, when freshening the motor take special note of the piston pin bores.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 12-01-2009, 09:48 PM   #4
Super73
Super73's Avatar
Gearing will not "change" operating RPM of a motor.
Operating RPM is typically a function of cam timing. There are other things that can hold RPM back like intake manifolds and headers that are not appropriate for a given combo. But in all reality it is a combo, and needs to be thought of that way.
Generally speaking and cam with a later intake valve closing point and more overlap will spin more rpm.
To Marv's point, piston speed can wear on bottom end parts very quickly. The heavier the components the lower you want to keep piston speed.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 12-02-2009, 08:18 PM   #5
Wild83C10
Wild83C10's Avatar
A.........
How did you figure gearing will help with RPM?????
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-02-2009, 08:19 PM   #6
Wild83C10
Wild83C10's Avatar
Why do you want to rev the motor to 7-7.5k rpms? What are you looking to do?
turbo=
Old 12-02-2009, 08:32 PM   #7
ripdog28
ripdog28's Avatar
I would like a 7-7,500 rpm limit for when i want to. I would not be at it all the time i just want an engine that can hit it.
69 c-10 BBC
Old 12-02-2009, 09:07 PM   #8
cableguy0
stuff will live a lot longer at 6500rpm than it will at 7500 especially in a big block. you base your gearing on your engines operating rpm. unless your drag racing only theres no need to spin 7500rpm unless you want to spend a lot of money trying to find a combo that doesnt fly apart and constantly break stuff.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-03-2009, 09:30 AM   #9
Alex1
Alex1's Avatar
Originally Posted by wild83c10 View Post
why do you want to rev the motor to 7-7.5k rpms? What are you looking to do?
x2
Alex1 is offline   Reply With Quote
Old 12-09-2009, 07:01 PM   #10
DieselEater
Correct me if I'm wrong.....But...
If you have an engine built to make peak power at 7500RPM, but your gears are in the "high way" range, say under 3.00 : 1...Then why wouldn't you get lower gears to put the engine into its power band?
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 12-09-2009, 09:01 PM   #11
ripdog28
ripdog28's Avatar
I have 3.70:1 rear gears. I will be able to hit 6500 easy just would like to go a bit higher when i want. The rpm power is very nice i was just looking at how i could add a few revs.
69 c-10 BBC
Old 12-09-2009, 09:59 PM   #12
Wild83C10
Wild83C10's Avatar
A........
Wrong.
You select the gearing based on what your power band is, transmission, tire size you have and what your goals are.
If I want an 1/8 mile car/truck and the power band is 4500 to 7k rpms then I could go with a really steep gear 5.XX:1. When I am going through the traps I want my engine to be at 7k+ rpms. Now if I want a 1/4 mile car/truck with the same engine/transmission/tire then I certainly can't run the same gear. I would need a lower gear. Either way the gear isn't going to affect what my power band is or how high my engine revs.
turbo=
Old 12-09-2009, 11:25 PM   #13
Super73
Super73's Avatar
Diesel,
The premise of changing the gear based on the racing your are doing, is correct. IE the example above 1/8 might need a 5.30 gear. Same car 1/4 might need a 4.11. Same car, standing mile, you might need a 3.42 in that car.
The idea of tailoring your gear ratio to the style racing you are doing is correct. But, if a motor can only spin say 6k rpm, going from a 2.xx gear to a 4.xx gear, your motor is still only going to spin to 6k rpm..
Old 12-10-2009, 10:32 PM   #14
DieselEater
Super73....
That was a great explanation of what you are all trying to say!
Things are a bit different with a sled hooked to you...LOL I understand exactly what you guys meant.
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 12-11-2009, 10:19 AM   #15
bigboybodry
bigboybodry's Avatar
JUST GRAB THE SECOND STAGE AND YOU WILL SEE AL THE RPM'S U WANT GREAT INFO GUYS THIS IS THE MOST HELPFUL PEOPLE IN THE INTERNET WORLD. KEEP UP THE GOOD WORK.
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 12-11-2009, 11:14 AM   #16
ripdog28
ripdog28's Avatar
I think ill stick with a 200 shot for a while. Never had juice and dont want to run wild with 2 stages right off the bat.. HAHA. Great looking set up you have there Bigboy.
69 c-10 BBC
Old 12-11-2009, 01:36 PM   #17
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by bigboybodry View Post
just grab the second stage and you will see al the rpm's u want Great info guys this is the most helpful people in the internet world. Keep up the good work.
dayum!!!!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-11-2009, 02:05 PM   #18
bigboybodry
my old combo was a 468 bbc iron headed 781 with port work,stock crank h beam rods, je pistons flat tap cam and i run 7000 rpm all day long. th400 3.73 gear 29.5/10.5/15 slick or street tires were 295/65r15 m/t et street.i forgot the 200 hp nos plate kit.that is what the shift light was set on. i ran the engine for 6 years and the only reason it broke was due to a faulty nos button (stuck) and before i got it shut down i got a piston. great combo i'll send you the cam specs. if you want.
Old 12-14-2009, 09:55 AM   #19
bigboybodry
Pm sent i hope that will help.
