Old 11-30-2009, 09:52 PM   #1
northern 85
northern 85's Avatar
Suggestions on flip kit.
Only looking for a couple more inches of rear drop, was thinking of rear hangers to go with my 2" drop shackles. After looking a prices, am i better to remove the shackles and install a flip kit? Any suggestions on who makes the best flip kit. Thanks
northern 85 is offline   Reply With Quote
Old 12-01-2009, 01:44 AM   #2
SCOTI
SCOTI's Avatar
Re: Suggestions on flip kit.
Yes, I would do a flip kit over shackle, hanger, & removed leafs. Bell Tech & Western Chassis both make quality flip kits.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-01-2009, 12:16 PM   #3
dropd80s
dropd80s's Avatar
x2 I would NOT get a DJM flip kit
dropd80s is offline   Reply With Quote
Old 12-01-2009, 12:59 PM   #4
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Mine is Western Chassis, worked great.
--Josh
Old 12-01-2009, 01:16 PM   #5
bigblock73
yeller
bigblock73's Avatar
WC kits installed here, 2 of them...was happy with both.
bigblock73 is offline   Reply With Quote
Old 12-01-2009, 02:01 PM   #6
Jonboy
Slots go on anything!
What does the WC run $ wise? Anything else besides shock relocators needed?
Old 12-01-2009, 02:09 PM   #7
SCOTI
SCOTI's Avatar
I got mine thru SportTruck Direct for about $150 as a kit w/c-sections, flip brackets, & shock extensions. Others have mentioned STD has had issues similar to CPP as far as CS goes so maybe check & see other possibilities before committing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-01-2009, 02:13 PM   #8
Jonboy
I have kind of been on the lookout. I am leaning for a 4/6 or 5/6 drop. I have a line on some spindles, and was going to cut the stock spring in the front. It will be a start.
Old 12-01-2009, 02:14 PM   #9
SCOTI
SCOTI's Avatar
Should work fine.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-01-2009, 02:57 PM   #10
3r!c84
Badass
3r!c84's Avatar
whys that????
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-01-2009, 07:01 PM   #11
Wild83C10
Wild83C10's Avatar
Northern the picture you saw of my truck where with the drop spindles and the rear flip kit. I had the western chassis flip kit along with the western chassis spindles.
If you don't use the truck to haul much stuff you could remove the overload spring. I did that in mine recently.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 12-01-2009, 07:58 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by 3r!c84 View Post
whys that????
I think there are better quality flip kits on the market. I feel like Western Chassis and Belltech are superior choices.
I think DJM makes a decent drop spindle,... but their Flip Kit c-notches and axle saddles are a cheaper design than the WC or Belltech version.
Keith
Convert to disc brakes.
Old 12-01-2009, 08:04 PM   #13
flamingbig10
6.0 powered square
flamingbig10's Avatar
I have a beltec on mine haven't had any problems with it
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-01-2009, 09:14 PM   #14
dbmx66
mgcuaghys flip kit went in perfectly
dbmx66 is offline   Reply With Quote
