Old 12-01-2009, 02:25 AM   #1
AJLChase
AJLChase's Avatar
So, I believe I installed flexplate wrong
Or, I unseated the torque converter and didn't re-attach it correctly as now I hear a heavy clunking around when the engine turns over but I can't go into gear at all. Does anyone know anyone around Lincoln who rebuilds transmissions or does anyone have any suggestions as to how I may fix a possible problem such as this? Thoughts?!
AJLChase is offline   Reply With Quote
Old 12-01-2009, 10:12 AM   #2
Tynee
I miss this truck.
Tynee's Avatar
Re: So, I believe I installed flexplate wrong
When you installed the tranny, did you "seat" the torque converter 3 times?
If not, that third "click" is when you would have engaged the tabs that drive the pump. If they were not engaged, you likely broke them off, and you will be in the market for a rebuild to repair that.
I learned this the semi-hard way. My buddy and I did it wrong the first try, luckily for me, it was his truck and his transmission.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 12-01-2009, 10:20 AM   #3
Muleman100
Muleman100's Avatar
Tynee is correct if you did not seat the torque converter for the three seat clicks you have a problem. You may still drop the tranny and see if there is any visual damage and redo and see if you are ok. I hope you did not do much damage.
Muleman100 is offline   Reply With Quote
