12-01-2009, 03:15 AM | #1 |
9" Rearend question
Hi need help with rear ends how do you no if its a 9" rear?? my nieghbor has a 1992 ford explorer xlt -- and a 1968 F100 and he said I can take what I need, but I didnt no if the rear ends are any good..dose any one know??
12-01-2009, 03:47 AM | #2 |
Re: 9" Rearend question
Here is a link with good pictures.
http://www.kevinstang.com/Ninecase.htm
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
12-01-2009, 03:05 PM | #3 |
the 68 should be a 9 and the explorer is a 8.8. either are a good choice go with the one in best condition
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
12-01-2009, 05:53 PM | #4 |
does the 8.8 in '92 have disc brakes?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
12-01-2009, 10:13 PM | #5 |
Thanks guys for your reply's good info. know the 92 ford is drum brakes....I wish..
would they be posi can you lift the back and spin tires and till or do you have to look in side??? |
12-01-2009, 10:36 PM | #6 |
mini truck racer
look at the tags on the diffs . Ford uses a code like 3L55 = 3.55 limited slip . An open diff will have a decimal point instead of the L .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-01-2009, 10:36 PM | #7 | |
Tripple Five Fanatic
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
03-09-2010, 07:41 PM | #8 |
can any one brake down this rear?
1996 Dodge 3500 4x4 1977 F250 Camper specal 4x4 1956 Chevy 3100 truck |
03-09-2010, 07:49 PM | #9 |
There is a number that's close to the nut that I can't see, it's not posi or locker, you want to find a tag with a L in the botton line.
Tri5
03-10-2010, 10:26 PM | #10 |
An easy way to tell if it's a 9" is a socket won't fit on the bottom stud. You have to use a wrench.
03-11-2010, 01:51 AM | #11 |
It's a 9" by the numbers on the tag but X.25 is the gear ratio and the 9 refers to 9".
Tri5
03-11-2010, 02:22 AM | #12 |
Insane In The Membrane
It would be 3.25 as the 9" only had one set of gears that ended in .25
03-12-2010, 03:30 PM | #13 |
25 9 is the tooth count. 25 teeth on the ring and 9 on the pinion which equals a 2.78 gears ratio. 25 devided by 9
03-12-2010, 06:04 PM | #14 |
ok thanks guys.
