still buypickupparts
stock oil pressure gauge
my truck is a 1/2 ton 72 short fleetside. well I have been wondering about the oil pressure gauge, for 1/2 tons they are 60 psi. did the larger 1 tons have 80 psi ? and I have tried serching a few times to google and here to find one. with not much luck I thought I'd ask on here if there is such a gauge for the instrument clusters that will fit right in without mods. and would the sending unit need to match the gauge? where can i find the gauge to purchase? oh I forgot to explain, allthis info would be for a mechanical gauge not electric
thank you for helping me with these questions
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
Re: stock oil pressure gauge
there is no sending unit for the stock oil pressure gauge the are mechanical gauges
umm, shows to me it was a little early when I started this post huh, but what about the 80 psi gauges were there any in these series trucks
The larger trucks came with 80 psi gauges and they are a direct interchange using your existing line and dash.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
![]() Join Date: May 2007
I think the 80lb gauges were used on big block trucks, regardless of series. I have two instument clusters that I pulled from large trucks because they had vacuum gauges. Both of them have 60lb gauges.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
![]() Join Date: Jan 2001
My '72 402/4-spd has the 80PSI one.
![]() Join Date: Aug 2007
This might explain why my gauge has always registered low.... (Big block truck with 350)
can someone recommend where I can get one? an 80 psi that will fit like factory?
I think they only make new ones of the 60lb variety. I bought a couple of used ones from a board member a while back. I would put up a wtb thread on the board. I'm sure you will be able to find one!
