Old 12-01-2009, 12:39 PM   #1
fatboys69
fatboys69's Avatar
Going to do the 5.3 swap
Going to pull my existing motor out and replace it with an 02` 5.3L with computer. Any of you guys that have done it or are doing it what am I in for ??
fatboys69 is offline   Reply With Quote
Old 12-01-2009, 01:07 PM   #2
JMARQUEZ_13
JMARQUEZ_13's Avatar
Re: Going to do the 5.3 swap
I want to do the same keep me posted on your updates.
JMARQUEZ_13 is offline   Reply With Quote
Old 12-01-2009, 02:42 PM   #3
Hart_Rod
Hart_Rod's Avatar
I have one in my 69 Burb and my 67 Crewcab. You can check both of my builds in my signature.
Hart_Rod is offline   Reply With Quote
Old 12-01-2009, 04:15 PM   #4
Shon
Mine (6.0/4l80) is in daily driver mode!!
Link in sig!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 12-01-2009, 04:37 PM   #5
no moa
no moa's Avatar
What do you guys do about wiring? Painless? Stock gauges? Stock key switch? I'm using an LT1/4L60E and those are my hold ups.
no moa is offline   Reply With Quote
Old 12-01-2009, 05:09 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
From everything I have heard, Nelson Performance is the way to go. They custom make the engine harness, I wish I would have went that way, just because the cheaper way isnt always a better way. Look at LS1Truck, LS1tech for more information. You can go with Wait4me performance, inexpensive but not pretty. If you go the latter way, PM me so I can tell you what to have them remove. It will make for a cleaner install. You can also do the harness yourself, look at LS1Swap.com.
More food for thought.
As far as the key switch and all that, stock is fine. however with the 4l60e, you will either need to change the tailhousing for a cable type or buy a digital speedo. if you are rebuilding the trans, go with the tail shaft. or you can just go with a 700r4.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Last edited by Clyde65; 12-01-2009 at 05:12 PM. Reason: adding more info and again
Clyde65 is offline   Reply With Quote
Old 12-01-2009, 05:25 PM   #7
Shon
I am using the stock harness but I can have the harness done for you if you want it.
I am using the stock gauges.
speedo is run with the Cable X box. it takes the VSS and turns the mechanical speedo.
Stock key switch.
LT1/4l60e: have you looked at the EFIConnection 24x set up? it sets up the harness to use the LS1 PCM, coils, etc. $1800 for everything and they have lower cost options. The benefits is no more opti and the tuning ability is way better with the LSx PCM, and not limited to 7k RPM limit like the LT1 pcm if you need to spin the motor that high.
Old 12-01-2009, 05:48 PM   #8
Ackattack
Ackattack's Avatar
you can read the last 2 pages of my 68 build thread. I answered a lot of these questions in there.
Hope to fire my 5.3L up tomorrow!
Ackattack is offline   Reply With Quote
Old 12-01-2009, 05:50 PM   #9
no moa
no moa's Avatar
Im not building anything to extravigant, I just didn't know how all the wiring ties into the truck. When i get to that point i'll decide, for now i have the engine, tranny, stock LT1 wiring. I'm going to yank the nose and cab soon and start the frame work, get mounts and tranny mounts and go from there.
Thank you all for the info.
Old 12-01-2009, 05:55 PM   #10
Clyde65
Clyde65's Avatar
Shon,
What is the cable X box?
Clyde65
Rebuild of Clyde
support our troops!
Old 12-01-2009, 07:37 PM   #11
tk-mpl
tk-mpl's Avatar
With the engine mounts and trans cross member of your choice it fits right in there. With alittle time, patience and research the wiring can easily be done by yourself. I fallowed alot of "68 short step's" threads to get most of my info.. There is alot info and other threads on here that will help you get it done and if not, just ask. Somebody will be happy to help.
Trevor
1968 short box stepside.
2007 5.3L 4L60, tuned w/EFI Live
2005 Silverado bucket seats.
Dominator 2600's all around.
Porterbuilt tubular control arms.
Magnaflow 3" dual exhaust.
tk-mpl is offline   Reply With Quote
Old 12-01-2009, 11:41 PM   #12
Shon
Shon,
Abbot Cable X
here is there website: http://www.atrol.com/cablex.htm
If anyone needs one contact me for pricing.
Old 12-02-2009, 11:13 AM   #13
Clyde65
Clyde65's Avatar
How much are they?
Clyde65
Rebuild of Clyde
support our troops!
Old 12-02-2009, 11:22 AM   #14
Shon
I will ship them for $300.
Old 12-02-2009, 11:28 AM   #15
Clyde65
Clyde65's Avatar
Well, dummy me, I didnt ask here before I bought a new speedo, I will probably do it when I do my dad's 6.0 for sure.
I appreciate it, very good price too!
Clyde65
Rebuild of Clyde
support our troops!
Old 12-02-2009, 11:32 AM   #16
Shon
I like the box b/c it allows the retentioin of the stock speedo/odo.
for me that was the selling point. very proud of it only having 109k miles on it.
Setting up the dip switches is EASY if using the VSS output from the PCM that would normally run the speedo in original vehicle.
Old 12-02-2009, 01:20 PM   #17
Clyde65
Clyde65's Avatar
Yes that is how my digital speedo hooks to the trans. NUTS!
Clyde65
Rebuild of Clyde
support our troops!
Old 12-02-2009, 09:03 PM   #18
brad_man_72
the boat guy
brad_man_72's Avatar
its not hard to get $1000 into the fuel system.
im using wait4me harness, everybody says it looks great?
original switch and guages, trying to put an s-10 speedo behing stock speedo.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-02-2009, 09:25 PM   #19
bbadfred
bbadfred
bbadfred's Avatar
Call John Spear at speartech. He will answer all your questions and either redo your harness or build you a stand alone engine trans harness and reprogram the stock computer. speartech.com in Anderson Indiana.
bbadfred is offline   Reply With Quote
Old 12-02-2009, 10:36 PM   #20
Puropedo
Shon, how much do you charge to redo (simplify) the original stock harness?
Puropedo is offline   Reply With Quote
Old 12-02-2009, 10:49 PM   #21
Shon
$450 to take a stock harness and do it up.
