12-01-2009, 02:48 PM | #1 |
Badass
flip kit problem
has any one had a problem with a flip kit and putting the rear end out of center like doglegging?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
12-01-2009, 02:56 PM | #2 |
yeller
Re: flip kit problem
What brand FK?
Be sure the axle cups/brackets are installed correctly. Most kits have an offset hole in that part (that slides over the leaf spring pin), to help correctly center the axle in its new location. If the truck dog legs, then that could be the cause.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 12-01-2009 at 02:58 PM. |
12-01-2009, 03:01 PM | #3 |
Badass
DJM
and yeah it has a off set to move the rearend back for the driveshaft and it is put in the right way.(the holes to the front if i recall) it only has 4% to the passenger side,we tryed unbolting it and hitting it around at school on the alignment rack.we could get it to 0% but when my tighten it back it moves back to 4-6% you can see them in the middle
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 Last edited by 3r!c84; 12-01-2009 at 03:03 PM. |
12-01-2009, 07:34 PM | #4 |
yeller
I would venture to say those cheap brackets are your problem. Either they aren't built to tight tolerances, or those holes are too big for the leaf centering pins...or both. If you saw the WC flip brackets (or other mfr's products)...you would never have purchased those...I wouldn't have at least.
DJM parts are cheap...and not just in price. Have you tried loosening everything up (leafs and all), sitting the truck on the ground (or rack), tightening down the U-bolts/flip brackets and then the leafs and shackles? That might help you.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 12-01-2009 at 07:39 PM. |
12-01-2009, 08:24 PM | #5 |
Truck Nut
I had a problem like that with a djm flip kit before. Alignment holes too big and too much play were flip bracket goes into the leaf spring saddle. I threw that junk away. You won't have any problems with Bell Tech, I didn't !!!!
Tony Kee Texas Square Bodies |
12-01-2009, 08:33 PM | #6 |
dang its hot
I used bell tech with no problems
12-01-2009, 09:11 PM | #7 |
i used mcgaughys, everything went in perfect.
12-01-2009, 10:31 PM | #8 |
Badass
damn sounds like i got ****ty parts..
we loseend the ubolts and hit the rear end with the hammer and moved it to 0% annd when we tighted it up it when back to 4-6% i was thinking taking one out and making the hole longer to look like this "0" to have the rearend move back more so it over compensates and when i tighten it up its at 0? i dont know sounds crazy
12-01-2009, 11:12 PM | #9 | |
12-01-2009, 11:37 PM | #10 |
Badass
no its not damaged yeah i was thinking that but i would be with out a truck when im waiting for the new parts
12-03-2009, 10:01 PM | #11 |
i used a wc flip kit and i haven't had any problems out of it i didn't need cnotchs either bought em but didn't use em, i just cut off the brackets that hold the bump stops
