01-22-2003, 05:41 PM | #1 |
Air Bag set-up 73-87
I've been trying to locate a complete bolt-on air spring system with no luck. I ordered 20 inch wheels for my ride so air-bags would be nice. I called a company K.P.components inc.(209-668-4057) outta CA and they said they are going to release a full bolt-on cantilever system for 73-87 trucks. The guy I spoke with (Anthony) said that the shop vehicle happens to be an 84 chevy and it would take approximately 2 months to develope and test. This was music to my ears cause' I was not looking forward to 4/6 or 5/7 without some bags. If anyone knows of a full system available currenty, please post some info....thanx
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction |
01-22-2003, 05:47 PM | #2 |
What about Air-Ride? They offer a system for the front & the rear is a bag over leaf set-up. Both are bolt-ons
01-22-2003, 05:56 PM | #3 |
The system we discussed was a 4 link with cantilever that eliminates the leafs and places the bags behind the axle for a less rigid ride. I left the company's name and representaive so thousands of us could generate interest.
01-22-2003, 08:34 PM | #4 |
Although w/limited seat time, I've ridden in a 82 swb that had air over leafs & felt it rode better than stock. This truck retained the main factory leaf + the longest leaf of the spring pack & tapered seat 1500# firestones. IMO it rode the same as my 68swb w/2500# bags mounted on the trailing arms. I have another buddy that has an 87 swb w/a weld on HD 4-link kit. He has ridden in my 68 & feels it's much less squirley than his 4-link going around corners & stuff. I do think the cantilever set-up would peg the kool factor though-- I just wonder whether it would actually ride any better.
01-23-2003, 03:23 PM | #5 |
Trucker.
FYI that's a lever setup not a true cantilever.
I've heard those KP setups ride extremely well and get the advantage of more lift associate w/ most lever setups. My ART parallel 4 link w/ F9000's rides awesome. |
01-23-2003, 03:30 PM | #6 |
5/8chevy, what valve set-up are you using?
01-23-2003, 04:02 PM | #7 | |
Trucker.
01-23-2003, 06:17 PM | #8 |
I think that's why my friends feels so squirrely around corners. He's using the manual controls for front/rear distribution, so when he goes around corners air is bleeding from one side to the other causing an exaggerated leaning condition. I'm using the same controls on my 68 but controling rear only (left/right) & that keeps each bag independant.
01-23-2003, 06:38 PM | #9 |
Trucker.
Yikes two way setups are scary.
The only way to go is 4 way controls. |
01-24-2003, 07:52 PM | #10 |
Under construction!
TTT I'm also interested in this setup. Keep us updated on the situation.
2001 Silverado bagged on 22's. *Sold* |
01-24-2003, 10:06 PM | #11 |
hometown heroes!
anyone got pics of their suspension w/ or wo/bags? I'm curious to compare the two, and to compare to my truck, since I bought mine at its current height. (5 inches off the deck. )
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th... Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee "Never give up ground you've already taken." -Unknown |
01-24-2003, 11:06 PM | #12 |
Trucker.
Before bags:
After bags: |
01-25-2003, 12:14 AM | #13 |
Hey 5/8, you and I have almost the same set up. How much pressure do you run in your bags. I haven't driven mine much so I am still experimenting.
01-25-2003, 01:28 AM | #14 | |
Trucker.
01-25-2003, 01:53 AM | #15 |
Thanks. I'll do some more testing tomorrow.
01-25-2003, 03:04 AM | #16 | |
Trucker.
01-25-2003, 03:24 AM | #17 | |
Under construction!
Sure has come along way this last year!
01-25-2003, 03:42 AM | #18 |
5-8, you still have those wheels that were on your truck? i think it looks damn good before (i think im partial to the colors).. sweet now!
01-25-2003, 11:31 AM | #19 | |
Trucker.
