12-01-2009, 07:25 PM | #1 |
Moderator
Where to buy E-Brake parts
I am just about to tackle the drum brakes in the rear of my 1/2 ton. I have all the parts I need, except for the E-brake parts (parking brake lever, arm, spring, cable) I think I can find the rear cables from a vendor, but I can't seem to find the other E-brake stuff anywhere. I have all of the other springs, self-adjuster kit, etc. Anybody know if they have the E-brake stuff at the parts houses? Thanks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-01-2009 at 07:25 PM. |
12-01-2009, 07:36 PM | #2 |
Re: Where to buy E-Brake parts
have you gone to a good local autoparts store? napa or carquest are my 2favorites for stuff like this
12-01-2009, 07:43 PM | #3 |
Moderator
Yup, I got all the springs, self adjusting kit, shoes, drums from Napa. But they looked at me like I was retarded when I asked for the E-brake parts. Every store and vendor on earth seems to carry the springs and adjusting hardware, but no e-brake parts. Same in the LMC catalog and the Truck shop and Brothers.
I need this white bracket, as well as the red bar in the middle of the second picture.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-01-2009 at 07:47 PM. |
12-01-2009, 07:52 PM | #4 |
Between Trucks...
Scott, I had no luck at the parts houses for anything other then shoes, drums and springs when I was looking for my '72. Might try the parts board.
Beat it to fit, Paint it to match... |
12-01-2009, 08:07 PM | #5 |
What?
The spreader bar is a catalog item, but the cable lever I haven't seen listed but I wasn't payin attention either.
Napa had all that stuff, and it was cheaper than the resto shops. (Same brand name on the parts)
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-01-2009, 09:46 PM | #6 |
Moderator
Do you remember what Napa called it or a part number? I have everything in the pic except those 2 things, and it appears they don't have it. I don't understand why they would have everything else but that. I will do some more looking cause I can't believe that nobody sells this stuff.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-01-2009 at 09:47 PM. |
12-01-2009, 09:52 PM | #7 |
I'm just going thru my rear drums also, and while I don't need those particular parts, carquest has had everything I've needed, and made in America, to boot. (for the most part) All that being said, I've seen these parts listed on many vendor sites. I'll try to find some links.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
12-01-2009, 10:04 PM | #8 |
Inline Tube sells the cables.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-01-2009, 10:09 PM | #9 |
Moderator
Thanks, I haven't had a problem finding those, but the E-brake stuff seems to be elusive. I don't need everything in the pic above, that stuff can be bought anywhere....just the E-brake lever in the first pic, and the red spreader bar in the second pic.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-01-2009 at 10:12 PM. |
12-01-2009, 10:16 PM | #10 |
Hey Scott, have you tried going to the junk yard? Iv'e found some pretty good e-brake parts there before for my 70 3/4 ton.
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
12-01-2009, 10:42 PM | #11 |
What?
The Napa website doesn't really get down to the small parts like that, so hopefully you have a store nearby you so that you can swing by and just have them dig through the catalogs behind the counter. At my store, I go directly to the comercial counter. Since the people at the front counters don't really "get it" right away.
I looked at the LMC catalog, and your spreader bar is on page 152.
12-01-2009, 10:53 PM | #12 |
Moderator
Thanks, I saw that one too. They list it for a 3/4 ton though Are they the same as 1/2 ton?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-01-2009, 11:30 PM | #13 |
What?
It's the same.
Come to think bout it, I may have a couple layin around. Hit me up if you want em.
12-01-2009, 11:35 PM | #14 |
Moderator
Cool, thanks for the info! I was hoping it was the same. I will do some more searching to see if I can come up with a kit. If I am unsuccessful, I will hit you up for those spreader bars. Thanks again! Do you know if the lever in the first pic is the same also? If so, I might be able to find a 3/4 ton parts truck and rob it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 12-01-2009 at 11:36 PM. |
12-01-2009, 11:49 PM | #15 |
I found this one, but it's for a 3/4 ton also.
http://www.americanclassic.com/images/BR2431.jpg So here's a question-Are all chevy 11" brakes the same? There are many many brake parts at inline tube, but they are all for cars.
12-02-2009, 12:22 AM | #16 | |
What?
12-02-2009, 12:24 AM | #17 |
Moderator
That is what I was thinking too. Thanks for the help. I might be picking up a 3/4 ton parts truck soon...if so I will be tearing it down and will check out the rear brakes.
12-02-2009, 02:19 AM | #18 |
Scott,
I will probly have those pieces in my 67 that will be going bye-bye. I will pull the drums tomorrow and let you know if you cant get any, I think I remember reading somewhere that they would be the same part for 3/4 and 1/2 ton, but dont quote me on that
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 12-02-2009 at 02:20 AM. |
12-02-2009, 01:03 PM | #19 | |
Moderator
12-02-2009, 05:01 PM | #20 |
SWBs: 67 2x4, 67 4x4, 70 4x4
I am looking for the clamp that attaches the cable jacket to the bracket under the steering column.
Any one have one of those?
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
12-02-2009, 09:11 PM | #21 |
Scott,
I got the parts off. I can ship them out to you if you like or I am planning on going to SoCal around the 19th and I can take them down with me along with the bed sills
72 C20 Longbed 05 1500 Z71 |
12-02-2009, 09:41 PM | #22 |
Moderator
Jorge- Sounds great! I am off that entire weekend. You can just bring that stuff down with the bed sills if you want. There will be some Mickey's big mouths here waiting too
