Just a car guy
swapping later spindles control arm question
Truck is a 1969 drum brakes.
I pulled the following parts off a 1980 c10, upper and lower control arms, spindles with rotors and calipers still attached. What do I need to put these on my truck? I thought I read that I need to use the later style outer tie rod ends. Will the prop valve off the 80 swap right into the 69?
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
A guy with a truck
Re: swapping later spindles control arm question
Upper/lower arms will bolt on. I would use the u-bolts from the newer truck as they are a larger diameter and probably not as rusty. You will likely want to snag the brake lines off the donor truck as well to make the caliper/prop valve connections easier. Otherwise you will need adapters. Adapters will also be needed for the outer tie rods. Easy solution to this again is to snag the entire steering setup from the donor- link, inners, outers, everything. Remember you're going to five lug from six, so new wheels too...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
