Water coming out the exhaust?
Started the truck today to leave from school, noticed a small amount of white smoke as it idled, grantid, it is about 50 degrees outside so i figure its normal, so i rev the engine as it warms up, and notice it sprays A LOT of of water out of the exhaust when reved. after the engine warms, this stops. My question is, is this just a temp issue? or is there something more serious to consider?
70 Chevy C10, LT1, T5, "Blue Beast" |
Active Member
Re: Water coming out the exhaust?
No issue - you just have condensation built up in the exhaust system
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Redefining LowBudget
your fine you can blame some of it on the new gas.......
one of my buddies from school lives in ringgold...if you get off the interstate by the CAT scales hes about 2 miles from there
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
your ride is about to blow!! stay away!! no, just kidding, A small amount of moisture is normall if the watar seems to be a lot to you just keep a eye on the coolant level to know for sure. Jim
Thanks for the awnsers. i figured it was condensation, but wasnt 100% sure.
Hottrucks, small world huh? you from this area?
