Old 12-01-2009, 11:00 PM   #1
omega
Engine Idle Trouble
I have a 1995 Suburban, K2500 with a 7.4L engine (this was the closest forum fit). When the engine is cold it idles at about 1500 rpm and when warm it is idling about 1000 rpm and will move at 8 to 10 mph on the level. There are no engine codes, have replaced the throttle posistion sensor, throttle control valve and engine coolant sensor to no avail.
Any suggestions on reducing the engine idle?
omega is offline   Reply With Quote
Old 12-01-2009, 11:43 PM   #2
clinebarger
Re: Engine Idle Trouble
Vacuum leaks? Ive found that its the throttle body base plate gasket alot of the time, cracked or broken vacuum lines, leaking intake gaskets, leaking brake booster, Throttle blades not closing. this belongs in the 88-98 forum.
clinebarger is offline   Reply With Quote
Old 12-01-2009, 11:46 PM   #3
bwood
bwood's Avatar
clinebarger beat me to it. Like he said, it sounds like a possible vacuum leak. Here is the 88-98 Group:
http://67-72chevytrucks.com/vboard/f...splay.php?f=12
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 12-02-2009, 02:29 AM   #4
omega
Thanks for the insights. I will move the post to right forum
