Old 12-02-2009, 10:00 AM   #1
srsummers
What is the difference with the 1954 and 1955 first series
Is the 54 and 55 first series simply a 47-53 with a different front clip?
srsummers is offline   Reply With Quote
Old 12-02-2009, 11:25 AM   #2
MrTucker
MrTucker's Avatar
Re: What is the difference with the 1954 and 1955 first series
one peice windshield and the roof lines are smoothed out. also the bed is different.
might be some minor interior changes too...
MrTucker is offline   Reply With Quote
Old 12-02-2009, 03:24 PM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
Bed is different. 54 and 551st should have an open driveline and could have a 235 instead of a 216.
Auto trans started about then in AD's
dwcsr is offline   Reply With Quote
Old 12-03-2009, 04:49 AM   #4
T Hilde
The dash is changed up a bit (noticeably).
T Hilde is offline   Reply With Quote
Old 12-03-2009, 11:04 PM   #5
Dan Bowles
AD Addict
The doors are the same. The hoods interchange but have different emblems in different locations. The front bumper is the same. The running boards and cab filler panels I believe are the same. The back and corner glass is the same. The seat is the same. Just about EVERYTHING else is different.
Cab: 1 piece curved windshield glass, completely different dash, different gauges, different knobs
Frame: different kick up in the rear, lower and flatter for the bed. Change to bell housing cross member to accomodate hydramatic trans which debuted in '54.
Bed: 2" deeper, flat tops, ribbed sides by the fenders, tailgate and tail lights change.
Front fenders: Recesses for marker lights, shorter front "overhang" where it meets the bumper.
Front grill: completely different
Front apron: shaped to match different grill
Open driveline: 55S1, 54 is NOT open
235 from 54 up (60 psi gauge)
Looks: best of ALL the ADs baby!!
Dan Bowles is offline   Reply With Quote
Old 12-04-2009, 10:25 PM   #6
T Hilde
Splitters Rule Dan!
The grille is actually the worst part of the 53-54 and then the bed. But we have had this conversation in another place.
T
Old 12-05-2009, 08:46 AM   #7
Dan Bowles
AD Addict
Originally Posted by T Hilde View Post
Splitters Rule Dan!
T
Mis-informed stalkers!
What's wrong with the bed? I can haul more splitter parts to the swap with a deeper bed! And bring home more BEAUTIFUL one piece parts. Oh, the eye soothing dash, the smooth curve of the windshield, the strength of that powerful chin. I think I'll go outside and admire the 3 I have sitting here!! Did I tell you we put a '54 grill on the 1 ton panel!!! Too bad it just isn't the same with a split glass.
Old 12-05-2009, 10:33 PM   #8
T Hilde
Don't care for the flat top on the box side.
Old 12-06-2009, 10:18 AM   #9
Dan Bowles
AD Addict
Where do you put your beer when changing your wide whites? Angle tops let it slide in!
Old 12-08-2009, 01:01 PM   #10
T Hilde
On the running board, its an easier reach and more likely in the shade. Plus, I can set the whole case there too.
Old 12-10-2009, 09:17 PM   #11
Dan Bowles
AD Addict
Hmmm...I've got 2" deeper bed. That's a lot more ice and another layer of beer. Slacker, Todd.
Old 12-10-2009, 10:56 PM   #12
T Hilde
I've got a 3600, you can have your 2 inches I've got another 12
Old 12-11-2009, 12:34 AM   #13
Dan Bowles
AD Addict
You win. This time. Don't make me go and buy that 3800!!
