12-02-2009, 12:10 PM | #1 |
Wheel solution
I was previously asking about Chrome Smoothies, but now Im thinking I can improve the look of the wheels by painting the white rims black... and returning the hub caps to chrome. Do you guys think the caps can be rechromed or stripped of that ugly blue paint? (photo below) Thanks
'51 Chevrolet 3100 |
12-02-2009, 01:33 PM | #2 |
Re: Wheel solution
Is there chrome under the paint? If so careful stripping might clean up nice. I suspect chroming them would cost as much or more than getting a chrome set of ebay, seems to be lots of them on there lately. I am looking for some67-72 4wd dog dishs for mine.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
12-02-2009, 01:35 PM | #3 |
more ideas than money
Re: Wheel solution
IMO it looks petty good as it is.
The caps should be able to be re-chromed, but it might cost just as much as buying different caps.
Randy 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
12-02-2009, 02:57 PM | #4 | |
Re: Wheel solution
So that solves the hubcaps, how can i get the white paint off of the rims? Can that be blasted with a pressure washer down to the steel and then re-painted with a couple of coats?
12-02-2009, 02:59 PM | #5 |
THE TOY STORE
Re: Wheel solution
pick up some airplane paint remover from autozone. stuff works really good especially on little areas like wheels.
having a badass truck and not driving it is like having a playboy model as a wife and not..... well you know. |
12-02-2009, 03:30 PM | #6 |
Re: Wheel solution
That truck is gorgeous leave it as is!
Nick
1952 GMC 1/2ton 5 window 1980 Chevy Suburban 1/2ton 2wd 2002 Chevy Silverado 1500 2wd 4.3l V6 quad cab |
12-02-2009, 06:09 PM | #7 |
Thanks 'til you're better paid
Re: Wheel solution
What about just buying repro chrome baby moons and rings for it and leave the wheels white?
http://www.classicparts.com/1947-53-...ctinfo/64-019/ Thats what I bought for my truck and I am happy with the quality.
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
12-02-2009, 09:26 PM | #8 | |
Re: Wheel solution
I think Ill try to pull off the White with the paint remover, then maybe repaint black and buy the repro hub caps. So what kind of black paint should i buy to paint the rims? Thanks
12-02-2009, 09:44 PM | #9 |
Re: Wheel solution
If the paint on the wheels is in good shape, Scuff them up and paint over top of the white. Scratch one of the hubcaps on the underside or edge to see if they were originally chrome.If so use that aircraft stripper that was mentioned in a previous post,Steve
12-02-2009, 10:35 PM | #10 |
Re: Wheel solution
The previous paint job on the rims was really bad... lots of paint was allowed to run down into the rims, so it should be stripped. What kind of paint do i buy and in what quantity? Thanks
12-02-2009, 11:36 PM | #11 |
Re: Wheel solution
I had mine sand blasted when my tires were dismounted. It was 30 bucks to do all of them. Then I powder coated the rims. Some shops will sand blast with the tires still on the wheel so that might work for you too. If you don't powder coat, go with a good quality spray paint like rustoleum. 2-3 cans should be enough. Like any paint job though, it will only look as good as what's underneath.
12-02-2009, 11:50 PM | #12 | |
Re: Wheel solution
12-02-2009, 11:55 PM | #13 |
Re: Wheel solution
I would go with whatever sheen matches the paint on the rest of your truck- so probably gloss black.
12-03-2009, 12:07 AM | #14 |
Re: Wheel solution
I think you should paint the rims blue to match, THEN go with stepped beauty rings and chrome smoothies. Just my $.02
12-03-2009, 01:22 AM | #15 |
Re: Wheel solution
You could try the Photo Shop section here and give them the ideas you might like.. They do a nice job!
12-03-2009, 01:25 AM | #16 | |
Re: Wheel solution
12-03-2009, 04:14 AM | #17 |
Re: Wheel solution
check body shops, machine shops, remanufacture shops. those places usually have a sand blaster.
53 Chevy 3100 1/2 ton 1st Armored Division, OIF Veteran |
12-03-2009, 07:59 AM | #18 |
Re: Wheel solution
I use a local Monument shop that does blasting,they blasted my Model A frame for $50.00.
12-03-2009, 08:35 AM | #19 |
Re: Wheel solution
My powder coating guy does sand and plastic media blasting. There is also a guy who is in the wood sign business who does sandblasting on the side. Try the yellow pages for a source.
K8O
1958 3100 w/55 frontend and 55 Cameo Bed (in progress) |
12-03-2009, 12:03 PM | #20 | |
Re: Wheel solution
Now i need to be thinking of what my painting steps will be. After the sandblasting, should i just tape the tires off and go get some spray paint cans of Rustoleum Gloss Black and coat each side of the rim? How many coats? How long to let them dry? Does that sound right to you all? Thanks
12-03-2009, 01:40 PM | #21 |
Re: Wheel solution
With the tires on??? Personally, I would do it right. Take off the tires and then have them blasted, use a good epoxy primer, and then if you are gonna spray bomb them, use several light even coats of color.
K8O
