Whats this wire for?....
Air Bag Question...
What is the lowest part on the truck if you use bags? Does the gas tank have to be relocated? What about the headders/exhaust? Not like I'll be able to afford the swap. I'm just dreaming.....
Kyle ![]() '82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders |
Garage Queen Material
lowest part on my truck with a 4/6 drop is my headers, so it will be the same with bags if you have full lengh ones.
Under construction!
On our trucks, the Y-pipe is first to make contact with the road (Talking about a factory-like setup now). The front cross-member and oil pan are also very low. The gas tanks don't need to be relocated in many cases.
2001 Silverado bagged on 22's. *Sold* |
Trucker.
Your tank will be about 3/4" off the ground once the control arms, y pipe and the tranny crossmember lay out. They will be higher if you have a normal bolt in notch.
![]() Here's what my setup looks like laid out. The oil pan is no concern. Last edited by Izzy; 01-23-2003 at 04:03 PM. |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
What Izzy said... Lowest part on the crossmember will be the lower control arm mounts... Here is the front of mine layed out.....stock spindles
![]() http://www.captkaoscustoms.com/images/bagged3.jpg
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#6 | |
Trucker.
Well, I have located a donor for one. It took a weekend to get it mine chopped. Once I get it out of the truck, it should take about 2 days. Are you wanting it finished up with the grinding, or just welded?
Wasn't Ryan (low 84) wanting the first one?
![]() I will have to find another one though, I guess I could sell mine if I have to... I have one drilled for bags already and could cut it for me.....
#9 | |
Trucker.
