Old 12-02-2009, 04:02 PM   #1
cheford
Black ceramic Hooker headers
I was wondering if anyone here is using the new black ceramic darksider headers that Hooker are producing. I'm using a 72 C10 2wd chassie for my build with a 350sb. What I need to know is how much clearance there is from the header tube to the front cross member as I have moved my motor forward 1 inch for firewall clearance of my F100 panel body. The Flowtech headers I have are hitting the crossmember and not allowing me to bolt them on. I'm trying to prevent surgery to the cross member if possible. Thanks to all how reply.....John
cheford is offline   Reply With Quote
Old 12-02-2009, 04:08 PM   #2
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Black ceramic Hooker headers
Just got a set of headers from Summit.
http://www.summitracing.com/parts/SU...9/?image=large
Installing tonight. Will report back.
Installed the driver side, only to determine that they touch the motor mounts. Also be sure that you dont choose long tube headers if you intend to lower the truck. I found that the collector hung below the frame rails.....
Ordering a set of Headmen's from ECE. The shorties made for lowered trucks.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 12-03-2009, 12:58 AM   #3
pmpski_1
pmpski_1's Avatar
I have the Hookers and they fit great. I didn't get the ceramic ones due to my budget at the time, but if I had to do it all over again I would have bought the ceramic coated headers.
pmpski_1 is offline   Reply With Quote
Old 12-03-2009, 07:45 PM   #4
cheford
Could you tell me how much clearance you have between the crossmember and the header pipe as this is the info I need. Thank you, John
Old 12-04-2009, 12:27 AM   #5
pmpski_1
pmpski_1's Avatar
There are a couple pics here: http://67-72chevytrucks.com/vboard/s...=284642&page=2
They're when I was mocking up the exhaust - I ended up getting it welded so it's a bit different, but you can see that there isn't very much clearance. The headers are still the same. I'll be out in the garage this weekend so I'll measure it. It's pretty tight, but the clearance is there.
Edit: My truck is a C20, so I don't know if that will matter. I've always heard the Flowtechs don't fit, the Hookers do.
Old 12-04-2009, 12:30 AM   #6
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
Be wary of black headers. They tend to fry plug wires and boots. The radiant heat can get ridiculous.
Are you considering heat shields around the boots?
suprachrgd82 is offline   Reply With Quote
Old 12-04-2009, 02:48 AM   #7
'72customdeluxe
But they're ceramic, not painted? Should still be good.
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 12-04-2009, 08:00 AM   #8
Huh?I`ve been running black ceramic headers since`04 with no ried boots.The whole point of ceramic is heat retension.Color doesn`t matter.Color matters with radiant heat,which is from an outside source,like the sun.Header heat comes from within and is held in better by ceramic coating.
Is this an F100 these are going on?I`m confused.
Old 12-04-2009, 10:02 AM   #9
cheford
Sorry for the confusion,lol. I've built my Ford panel on a 72 C10 frame for a nicer ride.
The black ceramic headers are rated better for heat compared to the polished ones, 1700* compared to 1300* according to Hooker.
Old 12-04-2009, 10:02 PM   #10
That`s what I figured.You must be setting on a 67/72 frame.Just wanted to clarify.
Yeah,the color of the spark plug boots is what will affect radiant heat.silver boots would reflect more heat and black ones would absorb more heat.I think being within an inch of any color headers is going to get radiant heat.
