12-02-2009, 04:20 PM | #1 |
Front end problem
Hello,
I have just begun getting a hop type shimmy when using my '87 V3500 1ton dump. Any ideas is it aligmnet , bad tires ? Does not matter if it is loaded or not happens every once and a while . Thanks |
12-02-2009, 06:26 PM | #2 |
Re: Front end problem
Sounds like it might be warped brake rotors. I have a similar problem with my 83 shortbed.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
12-03-2009, 02:04 PM | #3 |
I had that problem and it was Tires. Look at them and see what the wear looks like. Front end components could be loose as well. Tire wear will help tell you this as well. They wear funny for a reason.
12-04-2009, 04:58 AM | #4 |
ther eis about 40 things that go wrong on th efront end and they all lead to shimmy/death wobble.
tres are worn, no toe control tires are shot dle are worn. if its lifted at all, bad caster angle. old king pin springs/bushing/bearings need to be replaced. put a few large washers under the cap and arm to reload the springs. wheel bearings. wheel is bent, steering stabilizer is shot. leaf spring shackles are busted, bushing shot. |
12-05-2009, 02:44 AM | #5 |
i agree with the above post besides this quote. i guess 2 tons of fun hasn't ever broke a spring on a dana 60 front axle before. u think your hands are full now with a little deathwobble you'll have your hands full if the spring breaks i know it happened to me. the springs are about 4-6 dollars each new from most gear suppliers. i edont know whats cheeper a few washers or new springs |
12-05-2009, 02:56 AM | #6 |
never heard of one breaking before.
mine were .25" permenantly compressed so i stacked a 1/4" worth of washers back in and was good as new. |
12-05-2009, 03:58 AM | #7 |
so if your valve springs are compressed 1/4 of a inch you revive there longevity by stacking a 1/4 inch of washers?
12-05-2009, 02:53 PM | #8 |
hate to break the news to you but there is a slight cycling and usge differance between valve and kingpin springs, only a slight differance......
12-05-2009, 06:19 PM | #9 |
Tho the spring/washer trick does work, I think pinion angle has alot to do with it too. But since the truck is stock, not an issue..
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-05-2009, 11:14 PM | #10 |
a new spring is 4-6 bucks come awn its not that much money if your going to go thru the motions you might as well do it right. yes stacking washers does the trick for a short while the the plastic cup splits and wears out and you again get the deathwobble. bandaided not fixed.
12-05-2009, 11:27 PM | #11 |
how do you fix a wear item?
if you spent $6 for the new spring and $6 fo the new nylon how is that not a bandaid, its still going to wear out and compress. why spend the moeny for the spring and not do a full rebuild? if the spring and nylon ar shot so is the seals and lower bearing. it r a fix and you got suckerd for $12. i am still trying to figure out how you broke a spring. the load never changes unless you raise a tire off the ground, do you do a lot of jumping with 44's? |
12-06-2009, 12:48 AM | #12 |
huh? could not resit..figured i would bump
12-06-2009, 03:45 AM | #13 |
forget it
12-06-2009, 04:09 AM | #14 |
funny, i have had my washers in for 4 years, i, my neighbors, and the rest of the world arent dead yet. id say that is a pretty good "bandaid", must be cloth and water resistant too.
12-06-2009, 04:10 AM | #15 |
ill stop here, i wont post any more in this thread.
dont want to get band hammerd. any other questions or comments can be pmed to me directly. |
12-06-2009, 10:18 AM | #16 |
I've never heard of breaking a spring, even jumping it I can't see how.....
