Old 12-02-2009, 07:25 PM   #1
Fat Mike
Fat Mike's Avatar
What size do I use?
Can you use 3/16" 2x4 to build the rear portion of a custom frame or would it be too heavy? In all the builds I see everyone using 1/8" but I was looking at another website and they said they it could twist the frame? What should I use?
Fat Mike is offline   Reply With Quote
Old 12-02-2009, 07:30 PM   #2
cajundragger
Re: What size do I use?
you could do it.
but it is a bit overkill.
cajundragger is offline   Reply With Quote
Old 12-02-2009, 07:47 PM   #3
jjjmm56
jjjmm56's Avatar
how much of the rear frame are you going to build and is your suspension mounted to it?
jjjmm56 is offline   Reply With Quote
Old 12-02-2009, 07:52 PM   #4
Fat Mike
Fat Mike's Avatar
I am going to build from the rear cab mounts to rear bumper. I want to narrow it and put a 12" c-notch with a continued kickout. I am going to use a custom triangulated 4 link with bags.
Old 12-02-2009, 08:38 PM   #5
cajundragger
just roll with it. Although 12" is a too much.
Old 12-02-2009, 08:44 PM   #6
jjjmm56
jjjmm56's Avatar
Heres mine with a step notch and bags.
Old 12-02-2009, 08:45 PM   #7
cajundragger
that 2x2?
Old 12-02-2009, 09:40 PM   #8
jjjmm56
jjjmm56's Avatar
2x2x3/16 I can pick the truck up by the back frame with no flex in the step. Frame is fully boxed. The only weight it's holding is the back half of the box.
Old 12-02-2009, 11:53 PM   #9
BlueJeep
BlueJeep's Avatar
I used 2x4x.120 wall when I built this frame 3 years ago. No issues so far. If you're confident in your design and in your ability to weld, 1/8 wall is plenty.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 12-03-2009, 12:15 PM   #10
Fat Mike
Fat Mike's Avatar
I was reading the new classic trucks magazine and the truck on the cover has 2x4 3/16" wall tubing from the firewall back. Looks pretty good!!
Old 12-03-2009, 10:25 PM   #11
cajundragger
alot of people run 2x4x3/16.
which is why I said go for it.
but as usual, just because many run that, it doesnt mean its not overkill
I boxed my whole stock frame in 3/16. 1/8 would have been perfect, but I had 3/16 so I used it. all it did was make it really heavy and basically just as strong as using the 1/8.
