Old 12-02-2009, 08:47 PM   #1
kevmic28
kevmic28's Avatar
gauge lights 70 GMC
Some of my lights dont work. The speedo light does and one of the fuel lights does but the rest dont including my left turn light. I have pulled all the bulbs and checked them.. Whats my next step? Replace the wire board on the back of the gauges? I started to pull the dash panel off yesterday but decided to wait since the weather dropped and my only other vehicle is my Harley.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 12-02-2009, 08:56 PM   #2
Sammy
Re: gauge lights 70 GMC
If the bulbs were good when you checked them. You could try cleaning the contacts on the holders. I used some fine emery cloth to insure good contact. If you can see the circuit and it has some built up crud you might try a pencil eraser to brighten it up. I would try that before I replaced the circuit board.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 12-02-2009, 09:40 PM   #3
kevmic28
kevmic28's Avatar
Ok Ill try that this weekend when I have enough time to pull it apart.
1970 GMC truck
Old 12-02-2009, 10:15 PM   #4
cdowns
cdowns's Avatar
if you're going to b pulling them out to clean i'd just change out the bulbs too i've found new brighter than 40yo ones
Old 12-02-2009, 10:49 PM   #5
kevmic28
kevmic28's Avatar
I might do that. At 4 bucks for two bulbs changing them all will get kinda expensive.
1970 GMC truck
Old 12-03-2009, 12:17 AM   #6
OARNGESI
OARNGESI's Avatar
Wow thats pretty high i think mine was like 5$ for a box of 10 or 12 not sure pm me if you need some i got some extras ill give you
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 12-03-2009, 12:26 AM   #7
kevmic28
kevmic28's Avatar
I got them at Advanced Auto. I think I will do some shopping around to find a better price then.
1970 GMC truck
Old 12-03-2009, 09:43 AM   #8
JimKshortstep4x4
When you have the sockets out check them with the bulbs in them with an ohm meter. I have run into bad sockets that don't work even with new bulbs.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-03-2009, 10:42 AM   #9
kevmic28
kevmic28's Avatar
Im toying with the idea of taking it apart and painting the gauges and needles and installing some leds.
1970 GMC truck
Old 12-03-2009, 10:54 AM   #10
kevmic28
kevmic28's Avatar
http://www.thehoffmangroup.com/auror...e.php?gauge=93
This would look sweet in the dash.
1970 GMC truck
Old 12-03-2009, 11:28 AM   #11
DZL1
One day.....
DZL1's Avatar
Kevmic check out this thread:
http://67-72chevytrucks.com/vboard/s...inting+needles
I just did it to mine and am very happy the way it turned out. Also, i now that someone mentioned about taking very fine sandpaper and sanding the traces on circuit paper. I had to do that. I went out and bought 6 new bulbs and it turned out that i only had 2 bulbs that were blown. The sockets were the problem. What I did to fix that was sand them as well. There are 2 tabs that actually make the contact with the circuit paper, I sanded those. I also sanded the inside where the actual bulb makes contact with the socket tabs. Good luck. Hope this helps.
DZL1.
DZL1 is offline   Reply With Quote
