Old 12-02-2009, 09:14 PM   #1
spaseghost
certified tard
spaseghost's Avatar
windshield wiper and blinker question
not alot of time to do much in life anymore except work... fml?
so i have an issue with my wipers where they are fully manual. its off, low, and high. where ever i stop them is where they stay. motor or what?
and my left blinker doesnt shut of after a turn, the right one does though. cancelling cam? my truck will be mechanically sound once these two issues are resolved, and i get new tires...
85 swb bbc 5% tint
16.356 @ 84.81 8/07/09
4800 Ft., bad timing, carb tune, and traction, fugg it.
16.169 @ 84.29 8/28/09
good timing, no carb tune, some traction...
06 Equinox LT AWD, wife's and family ride
03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?!
90 Eagle Talon, other project / space taker, GOT head!!
08 Silverado 2500 HD, the bad ass work truck
spaseghost is offline   Reply With Quote
Old 12-03-2009, 08:23 AM   #2
71GMCNC
Re: windshield wiper and blinker question
I have the exact same problem on mine. Hopefully someone will chime in on this one!
'98 Chevy K1500 ext Cab Z71 4x4
196k miles and still going!
83' Chevy K10 Longbed 4x4. Dana 44 front and rear axles. Lift with 35's. Hopped up 350 V8, 4 speed manual w/granny. NP208 Transfer case SOLD!!!!
'71 GMC Shortbed 350 V8/Edelbrock performer intake and carb/Custom Dual Flowmaster 40 Exhaust
Currently in progress eventually 383 Stroker! SOLD!!!!
'67 Chevy C20 londbed Original 327 V8/4 Speed Custom Cherry bomb Exhaust
Inline to be next project sporitng primer grey SOLD!!!!!
71GMCNC is offline   Reply With Quote
Old 12-03-2009, 08:44 AM   #3
jaycrew1
jaycrew1's Avatar
spaseghost, I hear you about the whole work thing. I am there. Back to the problem at hand. I have been having some of the same issues with my wipers, but haven't had time to work out the problem. I used a post from another member about the wiring to the motor. I found out that I have a broken ground wire between the switch and motor. I haven't had time to fix it properly. Also, I am good freinds with the local chevy dealerships owner and service manager, they have let me barrow their 1991 chevy square body service maunal. Much of the diagrams in this manual work on the 80s model trucks too. I will let everyone know what I discover for this problem.
jaycrew1 is offline   Reply With Quote
Old 12-03-2009, 07:16 PM   #4
wydomkr
My wipers do the same thing, tried a different switch, no help, so it must be in the motor or the wiring. Apparently a pretty common problem.
On the t/signals, most definitely the canceling cam, one side broke off I'm sure. Some of these were replaceable without replacing the whole t/s switch, used to have the in the HELP section of most auto parts stores.
Keith
1980 C-10
1981 C-30
wydomkr is offline   Reply With Quote
Old 12-03-2009, 08:12 PM   #5
78 Chevyrado
Yeah, bad canceling cam. On the wipers, there's a disc like contact in the motor that turns as the wipers work. this disc has a slot for when the wipers get to the park position. this is what runs the wipers to the park position even if the switch is off. you can pull the motor off to see if you can clean up the contacts... otherwise just put a new motor on it.
78 Chevyrado is offline   Reply With Quote
Old 12-03-2009, 10:21 PM   #6
spaseghost
certified tard
spaseghost's Avatar
jaycrew1 - ill check the grounding on it tomorow, gots me a three day weekend! if it works ill let you know.
78 chevyrado - if the fround thing doesnt work ill try cleaning the contacts, hopefully no motor will be in order! thanks for the verification on the cam too.
85 swb bbc 5% tint
Old 12-04-2009, 12:04 AM   #7
westofb
I really hate wet sanding!
westofb's Avatar
your signals won't cancel most likely you have a broken spring that the cancelling cam contacts to turn off the signal. You can get these springs at most auto parts stores in there "help" line. I would get it apart and get it fixed because the broken spring is floating around the inside of your steering column.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 12-04-2009, 11:04 AM   #8
jaycrew1
jaycrew1's Avatar
hey guys, I don't know if this will help, but here is a layout of the wiper motor for you to look at.
Old 12-05-2009, 11:53 AM   #9
spaseghost
certified tard
spaseghost's Avatar
oh, right on man. i blew it up and printed it out. when the wife gets off work were gonna go look at this z71 tahoe and then im "free" for the rest of the day. ill post pics and stuff if i get it.
85 swb bbc 5% tint
