Old 05-23-2002, 04:26 PM   #1
Paul Clark
Post Cab Mounts
On the bigger rubber mounts do the ones with the metal plate attached go in front or back?
Same question about the smaller ones. 2 of them aren't completely round. They have a straight side.
Also, do you compress these when you put them on or just snug them up?
Paul Clark is offline   Reply With Quote
Old 05-23-2002, 05:28 PM   #2
bigvinnie
bigvinnie's Avatar
Post
The ones with metal plate are the front cab mounts, at least that's how mine are... you should compress them a bit, I believe they have a steel inner sleeve which will keep you from overdoing it...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
72 Stepside Project
bigvinnie is offline   Reply With Quote
