12-02-2009, 10:20 PM | #1 |
hard tops
I assume there are some major differences between the 69-72 tops and those from the next generation? I m new to the Blazer scene and figured this has been looked into...
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
12-02-2009, 10:44 PM | #2 |
Future TOTM Winner
Re: hard tops
Oh yeah, big differences. The 69-72 is completely different from the 73-75 and of course the 76-91 are even more different still. ALSO, keep in mind there are two different versions of the 69-72 tops. Looky here...enjoy.
Top linky
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
12-02-2009, 10:46 PM | #3 |
SKINNY TIRES RULE!
Re: hard tops
Welcome to the Blazer side of classic GM trucks. Just about everything to do with the body is different between the 69-72 and the 73-75 Blazers. For the 69-72, there are two tops, a double wall (69-72) and a single wall (72). The single walls are considered more desirable because they are lighter, don't sag or split as much, have interior dome lights and bolt down from above the bedrail so you don't have to remove interior side panels (if you have them).
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
