Old 12-02-2009, 10:27 PM   #1
6772fan
Active Member
6772fan's Avatar
Standard guage to tach swap-78 chevy
I bought a tach gauge cluster from BigJake on the board. It's from a 79 Blazer. The truck that it is going into is a 78 Chevy with standard gauges with electrical oil pressure switch.
Question- Is this a direct plug and play or does it require wiring modifications at the connector under the dash? The tach cluster comes with the tach wiring harness. Thanks.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 12-02-2009, 10:52 PM   #2
Jonboy
Slots go on anything!
Re: Standard guage to tach swap-78 chevy
The tach wiring harness is seperate from teh cluster harness. It will have 3 wires (IIRC), and plug in to the tach only. You may have to repin the cluster wiring. If you can get the pigtail from the donor, it will make everything a lot easier. The colors will be the same, but may be in different locations. You will probably have to swap temp and oil senders as well.
Old 12-02-2009, 11:02 PM   #3
ghettoluxury
ghettoluxury's Avatar
trace the circit board on both clusters and see if they are the same if so you are good 2 go if not re-pin to match
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
