Old 12-03-2009, 12:57 AM   #1
im tha best
im tha best's Avatar
heater isnt heating anything
My heater is blowing colder air than my moms new car AC. how do i fix it? its not fun when its 33 outside and you cant hardly turn the wheel cause your hands are frozen.
68 Chevy C10 long box
im tha best is offline   Reply With Quote
Old 12-03-2009, 01:14 AM   #2
kevmic28
kevmic28's Avatar
Re: heater isnt heating anything
Somebody just posted on here earlier about the same thing. Lots of ideas on that thread. Check here:
http://67-72chevytrucks.com/vboard/s...d.php?t=374706
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 12-03-2009, 01:16 AM   #3
im tha best
thanks dude!
Old 12-03-2009, 10:47 AM   #4
kevmic28
kevmic28's Avatar
Hey a quick fix would be to run by Northern Tools and pick up a small heater that plugs into the lighter. Not real warm but at least you wont freeze.
1970 GMC truck
Old 12-03-2009, 11:38 AM   #5
cdowns
cdowns's Avatar
taking heater core out and clearing out 40years of crap out of the housing makes a big difference
Old 12-03-2009, 11:46 AM   #6
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
Have fun taking that heater core out dude
It's not hard, but it is a lot of work. The good news is that new ones are fairly inexpensive.
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 12-03-2009, 12:32 PM   #7
northerngmc
northerngmc's Avatar
It may sound simple, but have you checked that you have sufficient fluid in the cooling system?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 12-03-2009, 12:50 PM   #8
kevmic28
kevmic28's Avatar
Also check your themostat. It may be bad and stuck in the open position.
1970 GMC truck
Old 12-03-2009, 03:16 PM   #9
69GMCLonghorn
69GMCLonghorn's Avatar
Luckily, the heater systems are not overly complicated on these trucks so it can only be a handful of things causing the no-heat-freezin'-your-n*ts-off syndrome. I spent one day going through mine a few years ago and had PLENTY of heat, even when it was 30 something outside (yes, it gets down there in the SF valley a couple times a year!).
Check that the barn doors are actually opening and closing by moving the butterfly valves, not the cables.
Clean the crap out of the heater box and make sure that leaves are plugging up the air flow.
Is the fan coming on? If not, check the motor, connections, fuse, etc...
There shouldn't be a heater control valve in the cooling system (assuming it's non-A/C), but if someone snuck one in, that might be an issue as well.
69GMCLonghorn is offline   Reply With Quote
