Old 01-22-2003, 09:22 PM   #1
72K10
cold temp steering problem?
In the last couple of days, my pickup's steering has been acting up. At low speeds, it pulls hard to the right - sometimes. I'll be driving along and all of a sudden, the wheel is turning by itself and I'm veering towards the ditch. This doesn't happen at high speeds (above 30 miles an hour) and only began three days ago. What I have noticed is when it's veeerrrrryyyy cold (10 degrees or so), it's bad. Anyone here ever hear of cold temps causing steering problems? What is it that's affected by the cold?
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 01-22-2003, 09:56 PM   #2
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
I'm thinking its your gear box. colder fluid is thicker and thats why its worse when cold. If it was a pump problem it would be a problem in both directions not just to the right.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 01-22-2003, 10:39 PM   #3
Piston
Piston's Avatar
Bad tire possibly... Check tire pressures. I would also cross rotate the front tires to verify its in the power assist. If rotating the tires does nothing (pulls in same direction) as mentioned, you'll probably find a bad gear box.
If it were mine, I'd rotate the tires then go from there.
Piston is offline   Reply With Quote
