![]() Join Date: Jul 2004
Need help with exhaust backfire
When i crank the blazer it runs fine but whan i try to drive it and accelerate it backfires out of the exhaust. I am not sure if it is doing it out of both sides of the exhaust. I understand that usually exhaust backfires mean too much fuel is being delivered and it is igniting in in the exhaust. Can anyone tell me what to adjust on the carb, is it the screws or the return spring. Could this be caused by anything else?
Thanks, chris
YELLOWBLAZER1969 |
Re: Need help with exhaust backfire
#3 | |
thanks, chris
YELLOWBLAZER1969 |
![]() Join Date: Jan 2007
In my case it was an exhaust leak at the manifold/exhaust tube that caused the backfire.
Upon rapid acceleration and then taking my foot off the gas would lead to a nasty backfire and if I let my foot off the gas slowly - it would be less likely to occur. I ended up replacing my manifolds and the entire exhaust - but the leak I had that caused the backfire was between the manifold and the exhaust tube(s). Good Luck! |
70 Chevrolet=Obsession
This may not be it but a bad coil can cause backfiring.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
