Old 12-03-2009, 12:56 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
Door Handles and Window crank Handles
I recently purchased a full set of these for a decent price. The catalog stated exactly as original. I did have one from a different vendor that was close, but not exact. The ones at GMC Pauls were stated as exactly like the originals. I found that to be true, They were really heavy and it was nearly impossible to tell the difference from my originals!
Just thought I would pass that on for any who might be ready to buy these.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 12-03-2009, 05:29 PM   #2
Ynotnow817
Ynotnow817's Avatar
Re: Door Handles and Window crank Handles
Thanks for the tip. How do you remove the oringinals?
Ynotnow817 is offline   Reply With Quote
Old 12-03-2009, 08:40 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for the tip, it's hard to know which are good without actually buying them first.
As for removing the inside handles there is a set screw at the hub under the arm part of the handle. If it's original it has a straight slot type screw. A long thin screwdriver works best for removing or tightening.
Old 12-03-2009, 09:37 PM   #4
63deluxfleet
63deluxfleet's Avatar
i need to buy some badd.. my passenger side doesnt catch idk if its the door part or the handle thats stripped.
A girl phoned me the other day and said... Come on over, there's nobody home. I went over. Nobody was home. -Rodney Dangerfield
.......THE ROAD TO HELL IS PAVED WITH GOOD INTENTIONS.....
63deluxfleet is offline   Reply With Quote
Old 12-03-2009, 09:55 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Unless the gearbox in the door is broken, it's probably the door handle itself. The splined shaft it attaches to is steel, while the handle is just pot metal. After years of operation while loose, torque against the toothed shaft has a tendency to chew the teeth out of the handle.
Old 12-03-2009, 11:08 PM   #6
Ynotnow817
Ynotnow817's Avatar
Thanks, I'll look tomorrow.
Old 12-03-2009, 11:51 PM   #7
LILRED66
LILRED66's Avatar
Interesting timing...I just pulled a nice shiny chrome aftermarket interior door handle from my door handle bin this afternoon and quickly noticed how much heavier it was, even compared to the originals. It didn't have any identifying marks on it, so I thought, this must be a good-ole "Made In USA" part, only to find a small label stating "Made in Taiwan". I wish I knew where it came from, because it was, by far, the nicest reproduction interior door handle I have ever seen...I have over 50+ originals in a bin and it is superior to all of them.
Back on the subject, thanks for the heads up ol curt. I will keep this in mind for the future.
LILRED66 is offline   Reply With Quote
Old 12-04-2009, 02:28 AM   #8
63deluxfleet
haha u guyz gave me the bug.. i broke down and bought a set, i also bought the cig lighter wire, and dome light lens. ill let u guyz know how it goes when i get em
Old 12-04-2009, 04:56 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
I did find that one of these had a phillips and the other slotted like my originals. The other one I bought used and allen wrench.
Old 12-04-2009, 04:57 PM   #10
ol Curt
Junior Member
ol Curt's Avatar
I have to admit these said they were made over seas as well, but they are VERY heavy like the originals.
Old 12-04-2009, 04:58 PM   #11
ol Curt
Junior Member
ol Curt's Avatar
Yeah, I would like to buy a lighter that allows my light to be hooked up to it. Somebody sells those original style with the slot for the light. I think it may have been Jim Carter where I saw those.
Old 12-05-2009, 12:41 AM   #12
Rich 5150 69
Rich 5150 69's Avatar
I had bought the left hand window crank assembly and handle for my truck, they both matched the originals and felt heavy the only problem I encountered was the handle fitment was sloppy, I used a piece of aluminum foil which tightened it up its been a year now and still tight. Eventually want to install power windows, I`ve already installed finger pulls to replace door handles.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
