Old 12-03-2009, 04:26 PM   #1
425HP409
425hp409
425HP409's Avatar
Smog Pump Part
I am in need of the right angle adapter that connects the diverter valve to the smog pump for my truck that I am converting from a small block to a correct (as best as I can do ) big block. I have circled the part I need in the picture. I also have a 72 big block alternator top bracket that I would trade for one for a 68.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 12-03-2009, 10:29 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
Re: Smog Pump Part
Does your top alternator bracket have the rear support rod? If so, i have a trade for you.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-07-2009, 11:14 AM   #3
425HP409
425hp409
425HP409's Avatar
Re: Smog Pump Part
No, I am missing the rear support rod.
Charles
90 ZR1 Corvette
Old 12-07-2009, 11:27 AM   #4
Duncan and son
Re: Smog Pump Part
Charles, In the process of getting feed back on your post looking for smog pump stuff if you get replys and they have smog pump items you do not need or if you have duplicates, Jason and I need the complete set up except the tubing which we have.
Appreciate your help Paul
Duncan and son is offline   Reply With Quote
Old 12-07-2009, 11:57 AM   #5
425HP409
425hp409
425HP409's Avatar
Re: Smog Pump Part
Duncan and Son
I will be sure and let you know if I come up with anything extra.
Charles
90 ZR1 Corvette
Old 12-07-2009, 11:22 PM   #6
Duncan and son
Re: Smog Pump Part
Hey Charles, You are a good guy and we appreciate your effort.
Thanks Paul
Old 12-08-2009, 11:07 AM   #7
DANTIP
DANTIP's Avatar
Re: Smog Pump Part
Paul,
I have at least one of those. If I can't make a set I would be happy to trade something for it. Any ideas?
Dan
DANTIP is offline   Reply With Quote
Old 12-08-2009, 12:57 PM   #8
425HP409
425hp409
425HP409's Avatar
Re: Smog Pump Part
Dantip,
I see you answered Paul, but I was confused what you had to trade, do you have the smog pump part that I need, or a whole set?
Charles
90 ZR1 Corvette
Old 12-08-2009, 01:00 PM   #9
DANTIP
DANTIP's Avatar
Re: Smog Pump Part
I definitely have the part but may be able to come up with everything except for the manifold tubes. I have the mounts/brackets, pump, elbow (the one shown), diverter, check valves, hoses and clamps. Just no manifold tubes.
Old 12-08-2009, 01:04 PM   #10
425HP409
425hp409
425HP409's Avatar
Re: Smog Pump Part
Would you sell the elbow by itself and/or with the diverter valve?
Charles
90 ZR1 Corvette
Old 12-08-2009, 01:05 PM   #11
Duncan and son
Re: Smog Pump Part
Hey Dan, thanks for your input. Let us know exactly what you have and we would be open for whatever works for you, we have LOTS of stuff. This will be going on a very nice very correct 72 BB loaded swb. Go to www.pickupsandparts.com and look under current projects to see what it is going on.
Old 12-08-2009, 01:09 PM   #12
Duncan and son
Re: Smog Pump Part
Second note, Let 425hp409 have what he needs then contact us. We have the manifolds and tubes but that is all.
Thanks again Paul
Old 12-11-2009, 11:49 AM   #13
425HP409
425hp409
425HP409's Avatar
Re: Smog Pump Part
Dantip, may I buy the smog pump elbow and or diverter valve from you. The main part I need is the elbow, but I will buy both parts if you want me to.
Charles
90 ZR1 Corvette
Old 12-14-2009, 06:50 AM   #14
DANTIP
DANTIP's Avatar
Re: Smog Pump Part
425HP409,
Here are two pics of the extension, correct bolts and used/unrestored diverter valve. Need $45 plus the ride.
