12-03-2009, 10:52 PM | #1 |
Rear interior side panel info
Seen a lot on this subject, but most interior pics of 1st gen's show k5's with no side panels. Just picked up a set of the chrome strips that hold the panels in at the top. Planning on some kind of custom setup and sure could use some pic's of what you guy's are running. The chrome strips I got are rusty, so I planned on cleaning them up and painting them. I don't plan on using original type side panels, but something custom with the original hold down strip. Going to go from hard top to soft top and back so am going to need a setup to withstand the weather. Any ideas or pic's would be great!
12-05-2009, 09:45 PM | #2 |
Re: Rear interior side panel info
Looks like I will have to do this on my own. Not a problem . Really looking at aluminum diamond plate, will last . Anybody got new pic's?
12-05-2009, 10:52 PM | #3 |
Its lookin' like a Blazer!
I've got some 3/8" plywood I'm going to use. Just cut to fit, glue on some 1/4" foam, then cover in 4 way stretch marine grade vinyl. I'm planning on using the strips I've got too. Same problem as you with them though. Theres a sandblasting/powder coat guy down the road from my shop. To do the 3" roll bar and the strips he quoted 200. I don't think thats too bad to blast it and powder coat it. I've seen the diamond plate before. Looks pretty neat. Unless you've got a connection I'd guess it won't be cheap. Then you've gotta figure out how to keep it from vibrating too.
12-06-2009, 12:13 AM | #4 |
My plans to. I'm thinking black diamond plate and use the factory bracketry. Maybe put some rubber pads between the diamond plate and the side panel to wall brackets to eliminate noise possbilities. I am working on my hardtop now and hope to have it back on in a week or so. I checked out prices on diamond plate online and it is expensive.
Jeremy (NUBOMB) 72K5 CST 350/350/205 1951 Chevy 1/2 ton North Georgia Group "... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman. |
12-06-2009, 12:48 AM | #5 |
Right on guy's! There's got to be a better way. I have the top strips now, but none of the other factory side brackets. Oh well, custom it is! Anybody got pic's ? I have plenty of 3/8" plywood, but am leaning toward the d-plate. Need some pic's of factory inner brackets, etc.
12-06-2009, 01:22 AM | #6 |
I'm just now fabbing my side panels.
I'm using 1/4" luan, which is a laminated weatherproof plywood that is very sturdy and lightweight. So far I've only cut out the patterns so I don't have good photos to show yet. I plan to use a 1/4" "U" Channel screwed down to the bed and around the fender wells to hold the bottom in place and I'm just going to use some stainless upholstery screws for the top. I plan to glue 3/4" foam to the plywood and then stretch fabric over it and add a few buttons to give it a little form. I will install my speakers, convenience lighting and 12v power outlets on each side. On the passengers side I plan to build a small door that will allow me to store battery cables, a quart of oil and spare fan belts etc.... I will double up the plywood around the openings if necessary, I don't have them cut out yet so I'm not sure if that is necessary or not yet. I'm a ways away from getting all that done but when I do I will post pics.
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
12-06-2009, 08:00 AM | #7 | |
Do you have a single walled top? If 'no', keep in mind when your designing the panels that each time you remove/install a double walled top, you'll need to remove the inner side panels to get to the bolts. Sure you realized it though... Are those old patterns still circulating around anywhere? (the ones Diane made and sent out) |
12-06-2009, 10:02 AM | #8 |
Yes, double wall top here. Makes this setup harder yet. Got to be a way to do it right. Thank's for all the help so far.
12-06-2009, 09:09 PM | #9 |
Double wall top,hmmm, I'm cutting some mobile home grade paneling to fit then cover it, mine's a CST so it has all the mounting bracketry; sheet metal floor anchors(1"X1" angle) etc. I think I'll go a little higher and not use the peeling chrome strips. Could you slip yours in a u-channel at the bottom and use super velcro along the top for easy in/out?
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
12-06-2009, 11:03 PM | #10 |
I've considered the super velcro.....not sure how that holds up with the top off at 80 miles an hour??
Screws won't let go
12-07-2009, 05:20 PM | #11 |
I did the diamond tread panels this go 'round & really like them. They don't rattle if you keep them screwed down tight. I don't like to try & keep them polished,useless PITA not to mention blinding yourself in the summer sun w/ top off, so I used a green scotch brite & WD40 to give it all a satin look!
I previously had an '85 K5 and made wood side panels that looked really good. Bought some nice plywood with a pretty grain & stained then cleared it all (sanding between each clear coat on the side that would be showing). Then used that Herculiner roll-on bedliner & covered the back and edges...they looked great and held up really well with a leaky top I'll post some pics later, they're on the other computer.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 Last edited by fun in dirt; 12-07-2009 at 05:29 PM. |
12-07-2009, 05:28 PM | #12 |
WD-40 & a Scotch-Brite pad, sounds interesting.
How does the WD-40 help? Inquiring minds... |
12-07-2009, 05:33 PM | #13 |
Makes it alot easier to rub with more consistent lines and takes out any water spots or other marks on the aluminum ...a more uniform looking finish!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
12-07-2009, 06:43 PM | #14 |
12-08-2009, 02:27 AM | #15 |
if you bend it like they do on duck work it will be more rigid and not rattle so much not to menchin if you do it in some way to make a design like small x big small agine just 2 cents worth All ready got the d plate to do it got it used not even shiny so I thought about doing 2 '' swarls or scales
12-08-2009, 02:08 PM | #16 |
New Member
Here's what was in mine when I bought it. Looks to be 3/8" plywood and has nasty old carpet glued to it with the chrome strips along the top. I have a single wall top.
12-10-2009, 10:45 AM | #17 |
Okay I finally found the pics of what i was talking about above
12-10-2009, 07:14 PM | #18 |
Yea, that d-plate looks nice! I have the double wall top, so am going to design them for easy removal. Like the idea of mounting some kind of c-channel on the bed to secure it on the bottom. Great ideas guy's, thank's! Black diamond plate? Where can you get that?
01-22-2010, 07:59 PM | #19 |
Hey, VT
There should be some patterns floating around out there. YellowBlazer made some for me and I sent them to another member...so they should be available. I've got mine going to the interior shop next week to get some foam and vinyl on them....I'll take photos when I get it back.
