12-03-2009, 11:31 PM | #1 |
Uncommon Dash Bezel?
So i went to a local junk yard today and found a 81-84 chevy(not sure as it had nothing to say what year it was) and found this bezel that someone removed.(They took the gauges which had the tach =( )...
It has a square in the middle top where it has light sockets for check engine light, which would be great for anyone wanting to install camaro tach and still keep the factory look as the camaro tach does not have a place for those lights. This is the back. up close I have never seen this type of dash bezel and wondering if it came from factory like this or if someone customized this. |
12-03-2009, 11:36 PM | #2 |
Re: Uncommon Dash Bezel?
I think it might of came off a diesel. There was a little glow plug light there maybe..not sure
12-03-2009, 11:36 PM | #3 |
Nothing to see here.....
does it actually say "check engine"? I wonder if it was out of a C40 or larger. iirc, in the larger trucks, the "engine overspeed" light was in that position.
hope someone will chime in and set us straight!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 12-03-2009 at 11:37 PM. |
12-03-2009, 11:39 PM | #4 |
Yes it says CHECK ENGINE on one side and the other side is blank.
It was a C20 shortbed truck. Last edited by KazuyaIB; 12-03-2009 at 11:40 PM. |
12-03-2009, 11:46 PM | #5 |
Extended cab fanatic
I believe its 86=87 bezel. The other light would say glow plugs. My 86 C30 has the same bezel with a 454 Use you imagination and figure out how to make it a shift light.
If it has a motor, it has my attention. Last edited by rare86; 12-03-2009 at 11:47 PM. |
12-03-2009, 11:54 PM | #6 |
6.0 powered square
84 to 87 with diesel
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
12-03-2009, 11:56 PM | #7 |
Now that you say that, it would be great for other things.... Il let you guys know what i decide to do with it.
12-04-2009, 12:00 AM | #8 |
Resident of Here
82-91 Diesel. My 83 and 84 have the same bezel. And other trucks I've driven have it.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-04-2009, 12:04 AM | #9 |
x2 my 82 had a diesel and had the same dash except in sliver one was a glow plug light the other was check engine if I remember.
12-04-2009, 02:45 AM | #10 |
HORSEPOWER JUNKIE
they were used in diesel and computerized electronic ignition models for check engine lamp or glow plug-water in fuel lamps I have 4 or 5 of these bezels loose and two in my trucks the last one pulled was a check engine lamp model from an 85 4.3 v6 short box with electric carb and computer controled ignition!
67 C20 fleetside custom camper 69 El Camino 72 Camaro 52 Dodge b3b 108 pickup |
12-04-2009, 03:06 AM | #11 | |
Kid's Mechanic
XIV. As of October 15th 2005 subscribing members will be the only ones permitted to post for sale and want to buy ads on any classified section of this site. link to all the rules; http://67-72chevytrucks.com/vboard/a...t.php?f=34&a=9 link to becoming a subscriber : http://67-72chevytrucks.com/vboard/a....php?f=34&a=17 |
12-04-2009, 09:12 AM | #12 |
Not all were diesels. I have one in my 84 that I pulled out of an 86 1 ton that had a 350. Truck was 100% original, so I know some redneck didn't put that in there.
I've seen it on more than one gasser. Who knows what GM was thinking. Maybe it was put together on a Friday??
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
12-04-2009, 09:37 AM | #13 |
Still plays with trucks
The warning lamp section of it pops out of the housing.
I didn't know there were check engine light versions out there. I'll have to keep my eye open so I can use it in the diesel housing I picked up. Anybody know how the lens section is held in the lamp housing part? It looks to me like it might be held in by a trim bezel that is glued in place.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
12-04-2009, 09:51 AM | #14 |
My 88 454 1 ton has this light as well. It lights check engine when I first start it up.
72 Super Cheyenne lwb 4X4 Ocra / White 88 Chevy 1 ton Dumptruck 88 Chevy 1ton Flat bed 4X4 white |
12-04-2009, 09:55 AM | #15 |
Slots go on anything!
It looks like there are retainers made into the light body that hold it into the bezel.
That bezel would be 84-up (no wiper switch hole). |
12-04-2009, 10:06 AM | #16 |
My 86 1 ton dually had the same guage bezel
12-04-2009, 04:27 PM | #17 |
>130dB Moderator
My '85 has that bezel. The heck engine light is in there. Mine is a 305/700R4 combo.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
12-04-2009, 05:04 PM | #18 |
my 86 c10 had it also with the check eng sign, my truck was from california, and i thought maybe it was some kind of emissions thing, not all 86 half tons had that window
12-04-2009, 05:32 PM | #19 |
Here it is
12-04-2009, 05:40 PM | #20 |
What are the other warning lamps on your speedo & fuel gauge?
Can you shine a light on the other upper space next to the check engine light and see if the other side of the bezel has anything on it? I have seen a few with no bulbs in the sockets for unused warning lamp spaces and am curious if there is a second function of the gas engine version of the center high warning cluster other side or if it is a true blank lens.
12-04-2009, 07:23 PM | #21 | |
Speedometer has 4x4 and choke lights Gas gauge has fasten seat belt and brake lights
12-04-2009, 08:02 PM | #22 | |
I currently have the SES & brake lenses put together in the speedo with no alt warning lamp because of the clock and the Camaro tach. If I can't find a T-400 splined NP205 I might need a 4x4 light too when I do the automatic conversion so that extra spot up high will come in handy. Thanks again for the info.
12-04-2009, 08:04 PM | #23 |
Out of curiosity is this out of your 88?
12-05-2009, 12:19 AM | #24 |
Yes its out of my 88. But it has the 87 body style.
12-05-2009, 09:54 AM | #25 |
Just trying to figure out the year ranges they did this with the gas motor trucks.
Looks like about 84-up with the square body from the different years people have posted.
