Old 12-03-2009, 11:32 PM   #1
1FAST68
help with brake line on 70 burb
Long story short, I switched to disc brakes off of a 87 truck. I got the lines prop valve all the way to the master cylinder, bought a new master cylinder for a 72 to go to my original power booster. It stops good great pedal but if I push a bit too hard the rear tires lock up, it is kinda dangerous when wet.
I think I may have the lines going into the master cylinder in the wrong holes.
Can somebody take a look at their 71-72 and see if the front resevior goes to the front brakes or rear?
68 chevy truck
ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft
70 suburban
350 tbi swap, 700r4, work in progress
1FAST68 is offline   Reply With Quote
Old 12-05-2009, 03:20 PM   #2
MrBinAz
MrBinAz's Avatar
Re: help with brake line on 70 burb
front (smaller) reservoir goes to the rear brakes.
sounds like you may need an adjustable proportioning valve to prevent rear brake lockup.
-----the fleet-----
'72 K20 Chevy Suburban
'72 Datsun 510 (vintage racer)
'89 Honda Civic Si HB
'89 Honda Civic Dx HB
'08 Honda Element EX-P
'78 Honda Express (50cc. pit-ped)
pix here
MrBinAz is offline   Reply With Quote
