Old 12-04-2009, 02:21 AM   #1
overtimeracing
overtimeracing's Avatar
Rear Axel and the tale of woe...
Hey guys... Ive been sandbagging for quite some time now gathering information. You see ive aquired a new project, (wasnt quite finished with the old project yet) but i feel youve gotta jump on an opportunity when it presents its self. My story is this: My buddy and I stumbled on a 402bbc @ the junk yard last winter in an old suburban and bought it pretty cheap. So I needed something to put it in of course. I had bee driving by these old chevy trucks sitting in a guys front yard, they had been there for a while, so i decided to see if they were for sale. One was a 65 sb and the other was a 63 lb. What was good on one was bad on the other.. you see what i mean? Anyways I bought them both, and have put the 63 cab on the 65 sb frame, and sold the other truck. Another buddy of mine was scrapping a 73ish 2wd pick up and gave me the front crossmember and suspension as well as the power steering box. These will be going in shortly. My problem is I dont know what to do with the rear. I would like to get the bolt pattern down to a 5 x 4 1/2 or 4 3/4, as i already have a nice set of Weld Draglights sitting around. So after that long boring story, my question is this: Is there a company that makes axels to fit the stock housing, or should I go with a different rear end? The one that is in there now I believe to be a posi, but I havent opened it up yet to verify. I promised the wife I would build this truck on a budget, and would like to use as many Junk yard/ slightly used parts as possible, but if I need to get axels...oh well. Thank you in advance for all your help. OTR
overtimeracing is offline   Reply With Quote
Old 12-04-2009, 04:20 AM   #2
tecky11
Re: Rear Axel and the tale of woe...
axels can just be redrilled to the bolt pattern that you want AND keep the posi!!!!
tecky11 is offline   Reply With Quote
Old 12-04-2009, 10:47 AM   #3
62gmc910
62gmc910's Avatar
The S10 s15 trucks with 4.3s had big 10 bolts in them 4 3/4 bolt pattern
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-04-2009, 01:22 PM   #4
overtimeracing
Thanks for the replies... Is the s10 axel the same width?? How about an 8.8 Ford axel. Ive been running one in my 68 Amc Javelin from an Explorer with good results. I believe they are 60" drum to drum.
Old 12-05-2009, 01:52 AM   #5
Captainfab
60-66 Nut
The '73 or so front suspension you got is going to be 5 x 5 bolt pattern. You can buy aftermarket 5 x 5 axles that will fit the '65 12 bolt. You could order custom aftermarket axles with whatever bolt pattern you want, but they are going to be a bit more $$.
I'm not too sure that a 10 bolt out of a S10 will hold up behind a big block very well. The '63-'69 12 bolts measure 62 1/8" WMS to WMS
Old 12-05-2009, 05:28 PM   #6
overtimeracing
Thanks for the info guys... Thats exactly what I was looking for... OTR
