Old 12-04-2009, 10:31 AM   #1
rattleon
rattleon's Avatar
Brake conversion help
I changed my '70 from all drum power assist, to disc up front w/ original drums out back. I changed out the prop. valve and using original booster. My question is can I still use the original duel res. master cylinder or do I have to change it out also? Is there a volume problem with the original? Thanks for any help.
1970 c-10 short/step box morphing into street/strip
1967 RS/SS convertible Camaro
1932 Henry Ford steel 5 window coupe highboy hotrod
1931 full fendered model A sedan AV8 traditional hotrod.
1934 Ford 5 window coupe and a (pile-of-parts)
1929 Model A coupe, plus our "normal" people vehicles.
rattleon is offline   Reply With Quote
Old 12-04-2009, 11:01 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Brake conversion help
subscribed I'm going to be doing this swap this winter
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 12-04-2009, 11:50 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
if you had drums 67-70 and went to disc 71-72 you need a 71-72 MC
John
1999 Toyota Tacoma 4x4
Old 12-04-2009, 02:19 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
The after market MFG's say you can use the original, But some originals have a residual valve in them and would make the front brakes hang. I would go with the 72 master to be sure. They only cost about $18 plus core.
dwcsr is offline   Reply With Quote
Old 12-04-2009, 02:54 PM   #5
smn69
I made the same change and the MC for Disc/Drum have larger resivors to handle the extra volume needed for the front disc. I would go witht the 71-72 MC.
smn69 is offline   Reply With Quote
Old 12-04-2009, 04:34 PM   #6
michael bustamante
michael bustamante's Avatar
good question. I didnt know about this
1967custom
michael bustamante is offline   Reply With Quote
Old 12-04-2009, 04:48 PM   #7
70 Suburban
Rods
i used my 72 m/c but its still a 50/50
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 12-04-2009, 04:53 PM   #8
smn69
Yes they are 50/50, but just bigger than the drum/drum MC
Old 12-04-2009, 04:55 PM   #9
70 Suburban
Rods
I wouldnt know. I used it in a 65 chevy.. they have a single port.
Old 12-04-2009, 06:25 PM   #10
cparman
sharp as a marble
I agree with old blue chevy. You need a disc drum master cyl
cparman is offline   Reply With Quote
Old 12-04-2009, 07:02 PM   #11
Hottrucks
Hottrucks's Avatar
nice to see we all agree...it's 50/50?????
Old 12-04-2009, 07:08 PM   #12
70 Suburban
Rods
Ha
Old 12-04-2009, 08:27 PM   #13
rattleon
rattleon's Avatar
Thanks for the input. It sounds like a volume thing more than anything else, so I'm going to play it safe and install a 71-72 m/c. $14.95 plus core and it's in stock at the local parts house. When it comes to brakes...that's cheap piece of mind, but damn!! that m/c top polished up so purrrdy!!!
