Old 12-04-2009, 12:05 PM   #1
69halfton
69halfton's Avatar
standard swap..clutch linkages
So Im going to start collecting parts soon to to a 5 spd standard swap in the 69 halfton.
its got a a pi$$ed of 383 stroker in it, so I'm going to want something that i can bang shift around pretty easily.
I dont have a question about the transmission, but rather the clutch, more specifically clutch linkages.
would the pedal assemby & linkage out of a 73-87 cab (specially a 1 ton) fit in under the dash of my truck? (I'm geussing not, my truck was also an automatic from the factory.. might make a difference.)
has anybody had an experience powershifting with a hydraulic clutch setup? are they sluggish? tough pedal?
maybe if i put oversize fittings and lines I'd have less flow resistance in the system?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 12-04-2009, 12:12 PM   #2
71tahoe
71tahoe's Avatar
Re: standard swap..clutch linkages
You should have a square brake pedal and the clutch pedal from a 67-72 is just a bolt on to your existing assembly.
The hydraulic clutches I've used have been easier to depress than mechanical ones.
71tahoe is offline   Reply With Quote
Old 12-04-2009, 10:56 PM   #3
69halfton
69halfton's Avatar
in other words, the linkage and pedal assembly from a 73-87 truck would not fit, or work under my dash?
- Jason
Favorite caption:
