Glen
Anyone with LED tail lights???
I'm looking at some LED tail light conversion and I see Dakota Digital has them for $200 and LMC has them for $120. Anyone used either one?
Pros.... cons? http://www.lmctruck.com/icatalog/cc/full.aspx?Page=75 http://www.dakotadigital.com/index.c...rod/prd563.htm I'm telling the wife to buy me a set for Xmas. ![]()
Glen Simpson Severed Ties - Oregon Roseburg, Oregon
Past Trucks
Glen
Re: Anyone with LED tail lights???
Anyone?
Past Trucks
Glen
Anyone?
Past Trucks
Custom Classic Trucks did an install recently. Here's the link:
http://www.customclassictrucks.com/t...all/index.html I would like to try them myself.
Jay 1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser. |
STILL PLAYS WITH TRUX
I dont have em on my truck but i put led bullet lights on my motorcycle and i had to get a specific led flasher unit so they would blink normal w/o it they flash way too fast and from what iv read about it, it can cause damage to the led circuit but if you only have them out back and the front are still normal lamps im not sure how that will work for ya.
Glen
Awesome! I just realized the difference. Dakota Digital has double the LEDs. That makes some sense for the price difference.
Past Trucks
Yeah, the Dakota Digital looks like a nicer, brighter unit.
![]() Join Date: Feb 2009
Still, $200?
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
I couldn't justify buying them for myself, but if I found them under the tree on Christmas morning, I wouldn't complain. Plus, when you look at what some people have in there trucks already with suspension, body work, rims, etc., what's another $200 in the grand scheme of things? I think it's a nice touch on a custom truck.
Glen
I'll probably go with the cheaper one. If I don't like them, I can also use it on my crew cab. I don't have custom taillights, and I don't feel like shaving them... so I'll fork out $120 for LEDs for that special touch.
Past Trucks
>130dB Moderator
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
In the Forgotten far North.
![]() Join Date: Jul 2007
I've got them in my Suburban behind my tinted lenses.
1. LIGHTS OFF 2. LIGHTS ON 3. PARKING LIGHTS @ NIGHT 4. BRAKE LIGHTS @ NIGHT
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#13 |
yeller
Wouldn't smoking the TL lenses kind of defeat the purpose of putting LED's behind them to brighten things up?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#14 | |
Plus it looks good too. ![]()
#15 |
Still plays with trucks
What about just using the direct replacement 1157 LED tail light bulbs?
I found some 39 LED 1157 replacements I was thinking of using and replacing the other lamps in the turn signal and running light system with LED's too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#16 |
certified tard
i put leds in my s10 and didnt need the blinker relay, but when one came loose after a long day of runnin around the desert it edidnt flash fast either. if you use led bulbs get the ones that have the leds on the top and sides, i think they are called towers.
85 swb bbc 5% tint 16.356 @ 84.81 8/07/09 4800 Ft., bad timing, carb tune, and traction, fugg it. 16.169 @ 84.29 8/28/09 good timing, no carb tune, some traction... 06 Equinox LT AWD, wife's and family ride 03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?! 90 Eagle Talon, other project / space taker, GOT head!! 08 Silverado 2500 HD, the bad ass work truck |
#17 |
Glen
Awesome info! Ace that's a great thread! Did you have to use a no load flasher?
Thanks for the photos BLE!
Past Trucks
#18 |
>130dB Moderator
No. Factory Flasher, factory fuses, factory wires.
I've had them in my truck for a couple years now and they are still as bright as the day I put them in. They are much brighter than the factory bulbs without a doubt. No moisture issues due to a bad seal or anything ike that either. LMC has found a very solid kit.
#19 |
Parts and more parts
I put the LMC kit in my truck two years ago. It was easy to do and it works quite well. I did not follow their pictures to the tee, I spliced them into the wiring and left the standard bulb sockets inside the fender, so IF I had problems, I could put standard bulbs back in quickly. They work great and are a lot brighter than the factory lighting.
Frank |
