Friday night work on the 70
Just getting the time to get some work done on the 70. I was wondering if anyone else is running DIYx4's cross member. Some before and after shots. Any advise on rewiring the entire truck?
1970 Chevy K10 350 CID with 4 speed 4" lift with 86 Dana 44 Front disk brakes Electric fan/Internal regulated Alt. |
Re: Friday night work on the 70
Looking good just got to love the 70's truck I am doing a frame off on my 70 that was my grandfathers... good luck with your build.
Junior Member
![]() Join Date: Mar 2009
Where did you get the motor mount setup?
atimic67 - The cross member and mount set up is from DIYx4. Really nice setup and cost effective.
Good luck on your build beechd18, I with I had the time and money to do a frame off. As for mine it is a work in patience. I just ordered a wiring harness and some exhaust gaskets.
looks great,
if your going to rewire the truck i recomend the painless 18 circut kit ivedone these in 4 vehicals and have never had a problem
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice new crossmember and I also see ya have tbi installed....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Yeah the carb was junk and I struck a deal and got the Pro Jection setup for almost free. I have had projection before and it seems to be a good setup, some people seem to complain a lot but I have been a satisfied customer before on a different project. I went with a 24 circuit from hot rod wiring - some nice seat heaters and other things to come and wanted the room to expand electrically.
thats a COOL engine mount setup..... just like those really cool tube trans mount/trailing arm mounts i seen on here.....
nice truck!! |
Between Trucks...
Nice work. That cross member looks killer.
Beat it to fit, Paint it to match... ![]() |
Thanks everyone, I made some more progress tonight. Mounted the front end and bolted down the intake and throttle body. Installing the fuel tank under the bed tomorrow, running all new fuel lines and installing the electric fuel pump. UPS man bring me my harness - lol.
1970 Chevy K10 350 CID with 4 speed 4" lift with 86 Dana 44 Front disk brakes Electric fan/Internal regulated Alt. Last edited by wpvtx; 12-06-2009 at 12:26 AM. Reason: adding pics |
![]() Join Date: Jul 2009
This may not be what you are looking for but my buddy and I did some fab work on my stock trans Xmember so we could run exhaust through it. After some grinding turned out very nice.
