'87 TBI - High idle and stick gas pedal?
Purchased a 1987 Scottsdale 20 this August and its my daily driver..... . Its a 350 TBI, and there is something wrong with the accelerator pedal. It is a little hard to press, for instance if I'm in creeper gear with the clutch out and no gas, i cant ease on the gas, I have to press hard and it lurches. Also, it idles high after a stint of being in gear, you go to stop and push in the clutch, it goes to 1800 or so rpm for about 3 seconds everytime. I was told that I need to clean the throttle body and that it would resolve both issues.... any input on this? Thanks.
1982 K10 SWB 1987 V20 - Sold - Doh! |
![]() Join Date: Apr 2009
Re: '87 TBI - High idle and stick gas pedal?
I had this sticking problem with my "TBI" . Thought for sure it was a sticking throttle body plate , removed throttle body and installed a spare one. Same problem. It wound up being one small strand of cable was catching inside the throttle cable housing causing it to bind up when accelerating and a high idle speed.
Be advised when I first checked the cable by disconnecting it from the pedal and throttle body it felt fine. But when it was all reassembled it distorted internally. New cable, Problem solved for me, anyway..... Desert |
#3 | |
Still plays with trucks
I had a similar problem with the same cause. Disconnect the cable from the throttle body and actuate the throttle with your hand. If it moves smoothly check how hard it is to move the gas pedal with it still disconnected from the throttle body. This will show you where the problem is.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
As for the surging, does it do it while at idle if the engine is warmed up. I was getting something similar a while back. TBI gasket was bad, easy fix though.
