Old 12-05-2009, 09:44 AM   #1
78-5.3
78-5.3's Avatar
91 speedometer
im trying to work out what i need to use for my speedo there seams to be 3 coppers strands going into the speedo head for the elec speedo now im useing this speedo in my 78 truck!!! anyone done this conversion please help shed some light !!!
78-5.3 is offline   Reply With Quote
Old 12-05-2009, 10:47 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: 91 speedometer
One will be the ground, one the ignition on power source and the other one the connection from the PCM telling it what to do.
I haven't found a wiring diagram that shows the connector pinout for the electronic speedo cluster so I can't tell you for sure which circuit is for what.
Can you post a pic of the back, maybe we can trace the circuits and find some common connection points I can identify with what I have identified on the older clusters. The gauges other than the speedo should still all be connected with the same wire configuration and colors.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-05-2009, 07:13 PM   #3
78-5.3
78-5.3's Avatar
Re: 91 speedometer
i noticed on the cluster there is 2 tan wire splice together going to fuel gauge seams to jump on the other side of the connector !!!
Old 12-06-2009, 01:44 AM   #4
Russell
Professional Grade
Russell's Avatar
Re: 91 speedometer
Hey -- I don't have enough time to type out a response for you here right, but please send me an email at Russell@ZieglerDigital.ca and I'll send you some detailed information on installing an electric speedo in your truck tomorrow evening
I put one into my 80 GMC, and I have pinouts for the DRAC, info on how to calibrate for tire size etc
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
