Normy71
Well off I go with my Build post I have been putting it off for a long time.
My 71 Gmc was purchased in April of 09 it was sitting in a snow bank and I was only able to get into one side of the truck. The motor ran quite nice but tranny only went in reverse .
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-09-2009 at 09:04 AM. |
Re: Normy71
Had to call a tow truck to get it out of the snow bank!
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-09-2009 at 09:06 AM. |
Re: Normy71
Started scratching my head wondering what I got myself into??
No rear pads left at all just steel on steel. And started the tear down
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-09-2009 at 09:08 AM. |
Re: Normy71
leaves anyone?
what a mess of crap in this truck 40 years of dirt grime and odds and ends. Only found 35 cents in change!! And Wont be needing this Engine Which did run good and is a 4 Bolt main. Maybe rebuild it someday with my son who is only 6 now but growing up fast.
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
Re: Normy71
Front clip ,cab,box
Got to love the engine hoist it does so much work in my shop.
Re: Normy71
The rust is quite bad but it has to come out!!
Re: Normy71
Getting a little work done
Picked up a 99 Camaro fuel tank.
Re: Normy71
Glad to welcome you abroad here! This forum is a MAJOR time killer-sooo much info and incentive to save these trucks, tough to turn away!
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
Re: Normy71
Well it looks like you got enough tin to get all that rust out. I'll look forward to see your progress on the cab so I can learn from your mistakes. LOL
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
Re: Normy71
What gas tank is that?
![]() nevermind '99 camaro.... cant read this early..... I do want to see it mounted!!! I need a tank for my 8.1l Vortec swap... Last edited by tonypaul; 12-06-2009 at 11:11 AM. Reason: added |
Re: Normy71
Had the frame sand blasted then painted with Por 15
Ready for C notch I made a template out of 1/4 plywood
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-09-2009 at 09:10 AM. |
Re: Normy71
More of the C notch need a good drill and bit for these frames they are made of good steel.( I did brake one 7/16 bit).
Hoist helps again when no help around to flip the frame! Also needed in every build a BFH!! Removing rivets and starting to mark out the frame for shortening
#13 |
Re: Normy71
More of the frame long to short.
Lots and lots of prep time measure measure ... I made the legs adjustable. Still need to fish plate the inside but run out of time..
Rolled the dice and lost!! ![]() Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 Last edited by Normy71; 12-09-2009 at 09:12 AM. |
#14 |
![]() Join Date: May 2005
Re: Normy71
nice progress normy71
#15 |
Tot Roddin'
Re: Normy71
Nice teardown and rebuild progress. Good luck with shortening!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#16 |
A320 Pilot/USAF Retired
Re: Normy71
Nice work. Hope to see a lot more of this one!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#17 |
Re: Normy71
Thanks guys!!
#18 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Normy71
Subscribing!
#19 |
Re: Normy71
Are you going to brace the frame where you shortened it. Thats how mine was done, but there is no plate welded in for strength..
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
#20 |
Re: Normy71
Time to jump around a bit I will leave the frame until I get to the steel store!
I welded up the gas line holes in the cab. A washer and a bolt worked perfect for this I stuck the bolt just flush with the washer welded it then had a handle to hold it in place welded the washer to the cab then cut off the bolt with a cut off wheel. Then on to the passenger rocker (which I should have done first like everyone suggests).. Lots of rust and dirt... and the weld cutter helps a lot along with a BFH!!
#21 |
Re: Normy71
Yes I will fish plate the inside of the cut and weld it all.
A must for frame work, don't just rely on a weld alone.
#22 |
Re: Normy71
Just thought I would post it is -32 C with the wind chill it is -40C
which is %#@# Cold!!
#23 |
Re: Normy71
Found some pictures of the drivers side floor and rocker repair
#24 |
Re: Normy71
What's the price tag on that rear floor section say?
#25 |
Re: Normy71
Tony!
I purchased most of my repair sheet metal from Scotts super trucks in Penhold Ab. Not sure what the price was?
