68 One Ton Dually, disc brakes?
I bought a 68 dually today and my brother picked it up outside of Springfield, Mo for me. I'll be headed to MO next weekend to bring it home. I don't know much about it yet other than it doesn't have much rust and the body is very straight. I've had a 67, 68 & 70, but they were all half tons, this is my first one ton of this body style. It has power brakes and power steering. Also come to find out it has disc brakes on the front. Those aren't original are they? Could the power brakes and power steering be original?
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#2 | |
Re: 68 One Ton Dually, disc brakes?
drum brakes on front |
Thanks. It has vacuum power brakes. I have a hydro boost unit that will be swapped in when I get started on the Cummins swap. I didn't think the fronts would be discs from the factory.
sounds like someone did the hard part for you by retrofitting the disc brakes. my 72 burb 3/4 ton has very powerful brakes right from the factory.
Yes, I'm glad that part is out of the way. It's not tough to swap discs, but I'm glad I don't have to mess with it this time. This way I can move right on to the drive train, body work, etc... I wonder how difficult it will be to locate a two speed rear end?
