'69 drum to disc front question
will disc spindles off of a 73-87 pick up fit on a 69?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: '69 drum to disc front question
Yes.
But you will have to change balljoints and outer tie rods. Search around in the "suspension section". This subject is talked about almost daily.
Also,...
WELCOME to the board!
Besides outer tie rods you will need custom adjusting sleeves because 69 inner and outer tie rods are thiner than 73-87 CPP has those CA sleeves
HaV0KSR559<~~~
I pulled mine off of a 72 and they work fine with the tie rods and balljoints on my 69
...1969_CUSTOM_1O
FLEETSIDE_LONGBED ![]() ![]() [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
That's weird,... because 71-72 ball joints and tie-rod ends are different than the 67-70 parts.
Grandpa in the rustmobile...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
HaV0KSR559<~~~
lol i meant 70...
simple mistake
...1969_CUSTOM_1O
