Old 12-06-2009, 02:43 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
NP203 won't go into hi-loc
I did the hubs and conversion, and now that it's snowed half a foot I can hardly get down the road in two wheel drive. I have the hubs locked, it'll go into Hi, Lo-loc, Lo and Nuetral, but it will not go into Hi-loc.
I've heard that often the linkage gets "frozen" could that be the case? and what's the cure to such an ailment?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 12-06-2009, 03:49 PM   #2
LONGHAIR
Re: NP203 won't go into hi-loc
Yes, most of the time the shifter is the problem. It is usually as simple as disassemble, clean-up, grease, re-assemble.
While doing this, you will notice that there are "alignment" holes in the levers. IIRC, this in the neutral position, so adjust your linkage if necessary.
BTW, it is generally easier to do all of this from the top. Pull back the floor mat and remove the tunnel...easy access, far better than laying on your back eating dirt and rust.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-06-2009, 05:35 PM   #3
Benelli
Benelli's Avatar
The tunnel as in where the shifter sits, just the 6 or 8 screws that hold in the rubber piece and metal outline?
Old 12-06-2009, 06:10 PM   #4
LONGHAIR
No, no...the tunnel is the entire "hump" area of the floor. It has several bolts that hold it in place along each side and a few across the back near the seat. It gives you lots of space. You wouldn't get too far through the shifter hole.
Old 12-06-2009, 06:31 PM   #5
OrrieG
OrrieG's Avatar
More info here...
http://67-72chevytrucks.com/vboard/s...d.php?t=371839
OrrieG is offline   Reply With Quote
Old 12-06-2009, 11:18 PM   #6
Benelli
Benelli's Avatar
So you would have to take out the seat then?
Old 12-07-2009, 08:23 PM   #7
LONGHAIR
Nope, just slide it back.
Old 12-08-2009, 12:43 PM   #8
willett
Another Day, Another Dollar
willett's Avatar
pulling the seat will make it easier though.
you may have to drop your tanks to get at the seat nuts on the underside of the cab though.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 12-08-2009, 05:18 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Those nuts should be welded in the floor pans, unless your floors are rusty or the welds are broken then you might have to.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
