PB Booster Bracket Question
Bought a used power brake set up for my C10 2wd suburban for the brackets push rod etc, It was from a C20 and had a double diaphragm booster. I replaced it with a new booster that is listed for a 70 C10 burb which is a 10 3/4" single diaphram. To me, it appears that the MC will be lower in the front than rear. I have it up on jack stands right now but it doesn't look right to me. Are the C20 brackets for a dual diaphragm different. They can go on only one way and the booster is positioned with the check valve where it should be. Any ideas?
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
"Trucks with Class"
![]() Join Date: Jul 2000
Re: PB Booster Bracket Question
Post pics...
Active Member
![]() Join Date: Jul 2007
Yep, they're designed that way. Not sure why.
