![]() Join Date: Jan 2007
sandblasting
I'm going to be sandblasting my frame soon and want your opinions on what I should use. I've done this befor and used white silicone sand. Since then I've found out that probably wasn't a good idea since you can get silicosis. This would be the reason I had some issue breathing afterward should have used a better respirator lesson lert.
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. ![]() |
Re: sandblasting
I used Black Beauty Media on my sheet metal. Works real good.....
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
Re: sandblasting
Use the Black Beauty on the frame, it is a little more aggressive than the sand and works well. Thats what I used on mine.
its all about the +6 inches
Re: sandblasting
I've been known to paint large vehicles in a small non ventilated garage, I'll sand paint and filler with no mask at all... I've even cleaned public toilets with no rubber gloves (way back in the day)...
However, when blasting with ANY media, ALWAYS wear some sort of mask. Last edited by Longhorn Man; 12-06-2009 at 08:46 PM. |
Son of a gun
Re: sandblasting
that silica sand it BAD stuff, stick with the commercially available medias. Most any will do OK, black beauty is one that will do better than others.
Oh, and I agree that you should wear a respirator.
Bill BEATERS ARE NEATER |
Re: sandblasting
Wear a good respirator (not just a dust mask) no matter what media you use. I'm not as up on the different medias as some of the other guys but Silica sand makes for a lot of dust floating in the air anytime you use it.
Re: sandblasting
If there is some one close by that dose it I would have it done. I weighed the options and it was cheaper to have it done over doing it my self. I just had mine blasted Friday.
![]() Join Date: Oct 2009
Re: sandblasting
I have done a lot of my own blasting. The problem with using "black beauty" and other media agents is the incrediable cost involved. I have "broke the law" and used a premium play sand available from Lowes. It is screened to one size and works well and only 3.50 a bag. It is important to note, however, I wrap up like a mummy with full eye, ear and lung protection. Don't skimp on a cheap respirator !
#9 | |
Re: sandblasting
HaV0KSR559<~~~
Re: sandblasting
What would you guys prefer for a good sand blastin set up
...1969_CUSTOM_1O
FLEETSIDE_LONGBED ![]() ![]() [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
Re: sandblasting
got this one about 25years ago have saved and made in the tens of thousands of dollars with it if i had to pay someone to blast my stuff
#12 | |
HaV0KSR559<~~~
Re: sandblasting
WHERE COULD I FIND MYSELF ONE??? IVE HEARD THAT YOU CAN BUY THE SAND BLASTING GUN AND JUST HOOK IT UP TO A REGULAR AIR COMPRESSOR TRUE OR FALSE??? AND IF SO IM SURE ITS NOT THAT SIMPLE WHAT ELSE WOULD BE NEEDED??? A ADDED REGULATOR N ETC??? THNKS FOR UR TIME ![]()
...1969_CUSTOM_1O
#13 |
Suburban Hick
![]() Join Date: Aug 2008
Re: sandblasting
If you got a local tractor supply or something of the sort you can usually pick up a 20 gallon one similar to the one above for baout $125. Personally we got a guy in town who will blast an entire frame perfectly for $100. You got to remember sand is anywhere from $4 to $8 a bag any more and then tips for those sandblaster are about $15 for four. I've found its about one tip for every two bags. So add it all up and its cheaper to take it somewhere.
Mathew 1947 Chevy 3600 1951 GMC 100 1969 Chevy C-10 396/500hp TH400 lowered 4" 1968 Imapla Custom 396/325hp TH400 "Grandmas Car" 1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505 1978 Chevy K-10 454 1983 S10 4x4 "Bumblb" (Grandpa's truck) 1993 Chevy S10 V8 conversion 1990 Ford Probe Gt 1992 Dodge W-150 "Old Man's Truck" 1992 Pontiac Grand Prix SE 1992 Mercury Grand Marquis-Mercruiser 2000 Ford F150 (Currently my mother drives this) 1946 Farmall H with Stan Hoist loader 1965 John Deere 110 1961 Wheel Horse " Rat Tractor" |
#14 | |
Re: sandblasting
#15 |
Suburban Hick
Re: sandblasting
I tried doing some things myself, like some of the small stuff and i gave up on it when i had got about $100 worth of supplies in a set of rims that i tried to sandblast at home and they still aren"t done.
#16 |
HaV0KSR559<~~~
Re: sandblasting
Id rather do it myself...
Because i dont know of ne one around here who would do it or of ne one who even has a blaster and if they did i would know of top it would be cheaper to do it myself...
...1969_CUSTOM_1O
